Standard sized stereo into 850 dash - convertors?
Post 33505 by jim_from_surrey on 2005-07-24 15:46:48
does anyone know where i can get an adaptor to go in place of the standard 850 stereo so i can fit a standard DIN sized cd player? it looks like the standard fit one takes up 2 din apertures - ideally i'd like to have a gap for the unused one so i can fit a CB radio there. anyone know of anywhere i could get such an adaptor? thanks Jim
Post 33507 by p fandango on 2005-07-24 15:57:53
a standard DIN unit will fit straight in when you remove the standard unit, all thats needed then is either a blanking plate or a storage pocket to fill the extra DIN slot (any car audio specialist of Halfords should have them in stock) i brought a blanking plate & cut out holes to fit extra gauges Image
Post 33510 by jim_from_surrey on 2005-07-24 16:24:21
thanks pedro, that looks good - is there just a hole left when the standard unit is removed or are there any side bracers etc?
Post 33513 by p fandango on 2005-07-24 16:30:50
when you remove the standard radio the actual hole is double DIN but it has a a small support each side so a single DIN will fit in & stay in place without any other brackets
Post 33514 by jim_from_surrey on 2005-07-24 16:36:50
[QUOTE=Pedro Fandango]when you remove the standard radio the actual hole is double DIN but it has a a small support each side so a single DIN will fit in & stay in place without any other brackets[/QUOTE] cool, thanks - out it will come! I havent got the correct code for the thing anyway, and cant get without taking it out and getting the serial number! thanks again. Jim
Post 33517 by p fandango on 2005-07-24 16:52:17
have you tried getting the code from a main stealer, just from the car reg plate they managed to tell me the code for my old radio
Post 33519 by jim_from_surrey on 2005-07-24 17:11:35
i havent tried that, no. might pop in there tomorrow to negotiate a price on a strut brace so will give it a go
Post 33553 by Vikingxl on 2005-07-24 19:47:19
You should have no problem fitting a cb in there as i have two head units in mine.
Post 33563 by jim_from_surrey on 2005-07-24 20:19:40
is there much extra depth in this area? the cb i want to fit is deeper than a standard stereo but narrower and not as tall so its only depth that could be a problem
Post 33564 by p fandango on 2005-07-24 20:23:03
[QUOTE=jim_from_surrey]is there much extra depth in this area? the cb i want to fit is deeper than a standard stereo but narrower and not as tall so its only depth that could be a problem[/QUOTE] no i'm afraid it was quite tight depth wise even for my radio
Post 33568 by Vikingxl on 2005-07-24 20:33:48
Mine was a tight fit as well not much room at the back at all.Are there no cb units available in a less deep size?
Post 33597 by M44K TS on 2005-07-24 22:33:45
[QUOTE=jim_from_surrey]is there much extra depth in this area? the cb i want to fit is deeper than a standard stereo but narrower and not as tall so its only depth that could be a problem[/QUOTE] May be something to try, if you find an ealier model 850 with the single din head unit, they have an odment tray that fills up the other din size for the radio apperture, they secure in and make the din sized hole slightly smaller. If you're creative enough, you could fit the tray in the free din space, then modify it by cutting the back out and somehow fixing the cb into that. maybe just a thought as my mate done that in his 306.
Post 34849 by jim_from_surrey on 2005-07-30 00:18:11
i didnt know the earlier ones had a single aperture and a compartment - that sounds a good solution for now. there are going to be a couple of cb rigs on the market later in the year that are standard sized but not at the moment. wonder if there are any 850's in my localish scrappy, gonna take a trip to find out i think!
Post 34888 by M44K TS on 2005-07-30 10:47:15
well my dads was a '94 and it had the single din head unit, so possibly upto '94 to look out for
Post 34909 by p fandango on 2005-07-30 13:51:28
as i said earlier, you can get either a blanking plate or pocket from most car audio shops or halfords & my 94 had a double din stereo
Post 34984 by jim_from_surrey on 2005-07-30 21:07:02
need to see what i can find down the scrappy i think... thanks for the input guys! Jim
Post 35004 by Kent Canary on 2005-07-30 23:19:40
Blanking panels are about 7 quid from Volvo
Post 36118 by jim_from_surrey on 2005-08-05 03:19:39
[QUOTE=Kent Canary]Blanking panels are about 7 quid from Volvo[/QUOTE] cool, i'd do that in petrol going to the scrappy!! (and my volvo dealer's within walking distance)
Post 36179 by swordy21 on 2005-08-05 15:41:26
[QUOTE=jim_from_surrey]cool, i'd do that in petrol going to the scrappy!! (and my volvo dealer's within walking distance)[/QUOTE] I'm sure Volvo also do a single DIN CD holder to plug gaps as well.
Post 36275 by jim_from_surrey on 2005-08-06 01:08:14
yeah, i saw a cd holder one go on ebay the other day, didnt get a chance to bid though as was in a hurry at a mates house at the time
Post 36298 by M44K TS on 2005-08-06 10:55:54
here you go... http://www.caraudiodirect.co.uk/product_info.php?products_id=657&cadid=a517c1717d46db25e20a244b704f3af2
Post 36386 by vt5 on 2005-08-07 06:57:19
Jim,, ive got one (the cd holder one) if you want it for nothing... yes it fits straight in and clips into place, then the stereo fits above it. easy peasy to fit.
