Post 33156 by audimadmike on 2005-07-21 22:54:27
My recently purchased T5 goes well but sometimes clouds of bluish/white smoke stops tailgaters getting close! Once fully warmed its minimal or absent. It's been suggested turbo bearings/seals. I've noticed no unusual noises.
Any suggestions?
Post 33179 by andi t5 on 2005-07-22 00:53:24
[QUOTE=audimadmike]My recently purchased T5 goes well but sometimes clouds of bluish/white smoke stops tailgaters getting close! Once fully warmed its minimal or absent. It's been suggested turbo bearings/seals. I've noticed no unusual noises.
Any suggestions?[/QUOTE yes sounds like your turbos past its best a rebuild may be the best step
Post 33251 by KARL on 2005-07-22 16:38:28
audimadmike
I also have smoke but only on some start ups (cold).Also when left to tick over
for a long time (hot) ,and then the first strike of the throttle will make 1 puff of blue smoke !
128,000 miles I have been told the turbo oil seals could be at fault.
Ps. It still flys
Cheers
Post 33255 by spesh on 2005-07-22 17:03:28
Karl that aint the turbo Mate, thats your oil valve stem seals! I have a brand new turbo on my car and it did that, well until I changed 10 of them!
Don't worry about it and it is a head off job to change them, only something like a pound each from volvo but aroung £600 labor to change them!
Post 33315 by audimadmike on 2005-07-22 20:29:27
Spesh..are you saying mine sounds like the valve seals? cheers Audimadmike
Post 33329 by spesh on 2005-07-22 22:09:26
Sorry mike, guess i didnt make my self clear, It sounds like Karls Valve stem oil seal are on there way out, it does sound like your turbo is on it's last legs, does it give off smoke for a few secs after you come off the power (full throttle) when warm?
Post 33330 by audimadmike on 2005-07-22 22:21:27
Thanks for update...It seems to smoke at idle or low revs, today I regassed the ac and switched off, ran again a few mins later while fully warmed up and at idle it poured out white smoke..revved slightly and after about a minute it cleared. At high revs it seems ok. If it is the turbo will it suddenly go? I cover long distances and don't want to be stranded.
Cheers
Post 33331 by spesh on 2005-07-22 22:25:43
If it is white smoke mate, i wouldnt say it was the turbo! White smoke tends to be water, have you checked the coolant level?? Some turbo's will go straight away, but there is normally a load whistel for a bit befor it! talking from experience
Post 33332 by audimadmike on 2005-07-22 22:32:46
Its mainly white but not steam, also slightly blue sometimes. No loss of coolant, oil and water all look as they should. It runs well and is returning 33mpg. Mike
Post 33967 by KARL on 2005-07-26 15:19:15
Spesh
Thanks spesh , will look into it.
Cheers
