Post 348628 by Filterlab on 2010-12-02 15:18:38
Quick question, I have a knackered front wheel bearing (OS) and the rear upper and middle TCA bushes are starting to wear. My question is; can these components be changed individually or is it a case of an entire new hub at the front and all new arms at the rear?
Thanks!
Post 348720 by lozccw on 2010-12-02 19:14:58
the front bearings ARE removable from the hubs, (whereas the rear bearings are fixed into the hubs)
as for the rear bushes-one end of the tca arms are removable, and the other is fixed
(the inner bush on each arm is removable, and the outer bush is fixed to the arm)
If you want better pics or any part numbers, let me know and I can send them.
