ECU and Engine Management Light
Post 346513 by SAMXPJ on 2010-11-22 19:32:46
Does anyone know how the ECU memory works with regard to holding on the various fault lights, for example if I pull my ECU how long would it need to be out of the circuit before it lost the memory or is there a relay type function somewhere? I am assuming the fault is now cleared and no further faults exist.
Post 346516 by p fandango on 2010-11-22 19:34:30
not all faults are automatically cleared like that, you many need to hook up a reader to clear them if you've solved the problem. Leaving the ECU out over night will clear others
Post 346586 by SAMXPJ on 2010-11-22 22:36:33
Yes I know BUT WHY, what system do they use to enforce this, there needs to be some form of electrical energy within the ECU or a mechanical relay somewhere along the line. Is there an electical cell in the ECU?
Post 346603 by SAMXPJ on 2010-11-23 00:21:53
I have just been told that it works in the same way as a computer memory stick ie magnetic ferric rings acting as gates so it seems the main stealer rules!
