Hu803
Post 344452 by spencem875 on 2010-11-14 18:31:34
So not having mp3 usage in the new S60 i thought id make up some discs, bad idea. It seems my HU803 does not like recorded discs. I have tried slower versions, fast version but none can be read. I had the same problem in my wifes Astra with the unit in that but managed to get CDR's to work. So anyone using recorded cd's in their HU803 and if so which 1's and how was it recorded?
Post 344453 by Chopster on 2010-11-14 18:52:32
My 803 play's cdr's, haven't come across any make's that don't play... the only thing I make sure I do is turn the recording speed down to 7 speed (the faster you record the less it burns onto the disc)
Post 344454 by Vikingxl on 2010-11-14 18:54:27
Spence this car is turning into a right headache for you matey
Post 344459 by spencem875 on 2010-11-14 19:07:19
[quote=Vikingxl;344454]Spence this car is turning into a right headache for you matey[/quote] I even listened to heart the other day :(
Post 344460 by Cubes on 2010-11-14 19:09:07
I have the same problem with my the 901 from my 02 C70. So I tried a couple of CDR's in a 53 plate C70 that was in the showroom and hey presto! It depends on the firmware on the circuit board. Doesn't matter what speed you burn with or on what brand disc, although I have heard that some brands do work - not for me! I have also tried burning on different formats ie. mp3, wav, etc. My way around it was to buy a changer for the boot. Plays everything I throw at it!
Post 344461 by Vikingxl on 2010-11-14 19:09:19
I think its time you got some help matey lol maybe ST will lend you his Miley Cyrus collection
Post 344471 by cherry1809 on 2010-11-14 19:55:32
Never have problems if I use Realplayer to burn with.
Post 344475 by spencem875 on 2010-11-14 20:05:07
Hokay burning with realplayer!
Post 344503 by spencem875 on 2010-11-14 20:30:23
Its official! i give up :) mp3 conversion inc!
Post 344556 by dobbin on 2010-11-15 00:12:19
try using 700 mb discs if you can find them im using tuffdisc brand in an 801 plus other brands but 800 mb discs have a diff lead in on them so it wont read them
Post 344663 by spencem875 on 2010-11-15 18:42:41
I use 700mb.
Post 344669 by cherry1809 on 2010-11-15 19:04:09
You had no luck with Realplayer? Mmm???
Post 344671 by spencem875 on 2010-11-15 19:05:04
Nein :(
Post 353865 by LeeT5 on 2011-01-09 12:05:02
[quote=spencem875;344452]So not having mp3 usage in the new S60 i thought id make up some discs, bad idea. It seems my HU803 does not like recorded discs. I have tried slower versions, fast version but none can be read. I had the same problem in my wifes Astra with the unit in that but managed to get CDR's to work. So anyone using recorded cd's in their HU803 and if so which 1's and how was it recorded?[/quote] I have the same headunit in my car. Mine plays copied discs fine, you just have to make sure you burn them at at least 240kbs. I burn mine using Windows Media player 11 and burn them at 320kbs. The quality is amazing and you can skip through the tracks just like a normal cd. I found when i used Nero and burn't them at a lesser quality ie 128kbs then they would not work and the disc would just skip to the next.
Post 353869 by Santa on 2011-01-09 12:18:48
Mine work fine burned using K3B on various CD-R media. Do your cds work in any other standard CD player?
Post 357886 by spencem875 on 2011-02-02 19:40:26
[quote=santa20;353869]Mine work fine burned using K3B on various CD-R media. Do your cds work in any other standard CD player?[/quote] Da!
