ABS Ecu 850 t5
Post 340276 by p0xy on 2010-10-24 15:56:25
Wanted a 850 t5 abs ecu model number 9140773..Tried to fix mine a few times and the abs went off for a while. so after another one thats working as cheap as possible .. cheers
Post 340386 by Wobbly Dave on 2010-10-24 22:15:45
have you checked your reluctor rings.
Post 340488 by p0xy on 2010-10-25 15:54:20
are they easy to get to??? I resoldered my ecu and it went off for a while. then redone it which i think i might of made a balls of it, thats why its on permanently now :s.. I got it checked and it came up rear right abs sensor, so i presume its the abs ecu.
Post 340493 by Mrsmastiffs on 2010-10-25 16:30:47
Hi, if you are still looking there is one on Ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120636600463&ssPageName=ADME:X:RTQ:GB:1123 I want one as well but mine is 9162675
Post 340516 by p0xy on 2010-10-25 18:07:35
ty mrsmastiffs will watch that :)
Post 340613 by Wobbly Dave on 2010-10-25 23:56:07
reluctor rings are the castlated rings on the end of the outer cv joints... Image
Post 340623 by dicky b t5 on 2010-10-26 09:19:00
How do you check if these rings have gone t1ts up then Dave ? Do they split or something ?
Post 340661 by Wobbly Dave on 2010-10-26 16:27:28
split - or damaged/missing teeth. Symptoms when driving are ABS Light (obviouly) Firing of ABS for no obvious reason especially at slow speed. Take the wheel off and inspect. You see easily if teeth are missing or it is split. Good news is that you can buy them separately (you need not buy the whole CV joint outer end). Only after the ABS ECU & the reluctor rings are defo not at fault would I actually look to replace the sensor (based on DTC readings).
