I also got some new wheels lol
Post 339341 by Brett855tdi on 2010-10-19 23:27:25
Many thanks to Claymore!! The clear coats just hardnening off ready for some tyre swaps and fitting in the morning! i will post some pics of them on! but for now heres a before and after! Imageafter; Image
Post 339387 by BruceT on 2010-10-20 12:30:19
Very nice. I was tempted to do mine a anthracite colour, but look ok in silver I thnk.
Post 339393 by Brett855tdi on 2010-10-20 13:01:20
Here they are! they look well, and the volvo caps just squeezed in! the down side is one has a buckle and its either that or the muppet at quik fit not balenced it properly, taken the smooth ride away :( so will probably still be looking for another set Image
Post 339395 by claymore on 2010-10-20 13:20:57
they look good on there bud, i didnt notice any buckles, having said that I never actually looked. is it shaking through the steering?
Post 339422 by BruceT on 2010-10-20 14:55:46
A small buckle, id imagine you mean a little kink in the outer or inner edge? Unless its serious and all the way through, I doubt you would feel this. It will most likely be bad wheel balancing, take it back and get them to re-check it
Post 339455 by Brett855tdi on 2010-10-20 19:07:28
yer its one on the front its had a bash on the inside unusual i know! only really stuck ou while he was balanceing it i noticed the woblbe, as i used to do that sort of work for abit i have a keen eye for it! but its shaking at what i think is 70 and then 90 (no speedo at current) No that i go over any speed limits on the road! so i do think its the balancing really, he put the weights on then took the wheel off, he didnt spin it again to make sure it was right. I shall take them somewhere else, loads of berks in there.
Post 339464 by Brett855tdi on 2010-10-20 19:50:14
Image Image
Post 339785 by 850 2.5 10v on 2010-10-22 13:47:03
That car needs dropped.
Post 339788 by Brett855tdi on 2010-10-22 14:26:39
[quote=850 2.5 10v;339785]That car needs dropped.[/quote] Indeed! one thing at a time! She needs a service more importantly at the moment, also the CV joint (hopin to get done today, dam hub nut!)
