Post 329610 by slim1122 on 2010-09-05 12:59:31
hi all need some help with my old bus i got it going a bit sideways the other day and had a blowout jacked it up changed the wheel job done. but then i droped the jack and that corrner was sitting about 40mm lower that it useto. it has all ready been lowered 50mm so the shock is now rubbing on the rear axle controll arm the tyre is hitting the inner arch and it srcubing the tread had it up on a jack to day with the wheel off and had a look all the bushes are there and the spring dosent look bent any one got any got a clue what it could be would a soft shock make it sag more? thanks craig
