stereo change do leads need inbuilt power converter? any idea
Post 313063 by watchmytracer on 2010-06-04 20:53:57
Hi am i am currently trying to change my existing 801 stereo on my 850 with my sony head unit on visiting my local car shop i have ordered what looks like a straight dual converter lead is this correct? pictures look right .reason being a friend of mine asked someone else and they said the lead should have an inbuilt box / power converter in it is this true any light on this would be fantastic cheers all
Post 313064 by Flatout Phil on 2010-06-04 21:00:28
[quote=watchmytracer;313063]Hi am i am currently trying to change my existing 801 stereo on my 850 with my sony head unit on visiting my local car shop i have ordered what looks like a straight dual converter lead is this correct? pictures look right .reason being a friend of mine asked someone else and they said the lead should have an inbuilt box / power converter in it is this true any light on this would be fantastic cheers all[/quote] I have just today discovered a similar problem - in that I have received a Sharp to Volvo conversion lead, but do not seem to have any sound coming from the speakers! That said, the cable marked AMPLIFIER that I removed from mc SC unit does not seem to have a home on the Sharp unit. Any ideas? It is getting power.
Post 313066 by polak t5r on 2010-06-04 21:05:19
sorry for the hijack but if you've both removed your stnadered equipment i dont suppose any of you have got the multi changer leads have you i'm really struggling to get them sorry again for the hijack on your problems i did it on a 95 850 t5 and it was just a straight iso conversion and it worked fine didnt need any more cables
Post 313109 by Unknown on 2010-06-05 01:30:44
i fitted a dvd multimedia double din head unit in my 850 t5r and all i bought was an iso double block conecter one of these: http://cgi.ebay.co.uk/Volvo-850-940-960-C70-S70-Car-Stereo-ISO-Lead-PC2-37-4-/170469750139?cmd=ViewItem&pt=UK_CarsParts_Vehicles_FasciaPlates_SM&hash=item27b0c9f57b and mine works fine on the 8 speaker set up. power and rear speakers was on 1 block and the front speakers was on the other block. please note to get ur front speakers working u have to unplug the secondry block from the wiring ur see lurking amongst the rest of the wires (just look for a plug conector simular to the one on ur iso lead). if u guys have a problem i can take pictures for you and post here ok :D
Post 313112 by claymore on 2010-06-05 08:02:52
[quote=the-man-that-can;313109]i fitted a dvd multimedia double din head unit in my 850 t5r and all i bought was an iso double block conecter one of these: http://cgi.ebay.co.uk/Volvo-850-940-960-C70-S70-Car-Stereo-ISO-Lead-PC2-37-4-/170469750139?cmd=ViewItem&pt=UK_CarsParts_Vehicles_FasciaPlates_SM&hash=item27b0c9f57b and mine works fine on the 8 speaker set up. power and rear speakers was on 1 block and the front speakers was on the other block. please note to get ur front speakers working u have to unplug the secondry block from the wiring ur see lurking amongst the rest of the wires (just look for a plug conector simular to the one on ur iso lead). if u guys have a problem i can take pictures for you and post here ok :D[/quote] I'm about to fit a double din tv/dvd tomorrow, so any picks would be good.
Post 313161 by Unknown on 2010-06-05 13:32:23
oki doki claymore i took it on myself to take me head unit out and get sum pics of the iso block and to show which secondary block has to be unplugged from the original wiring loom this secondary block is for ur front speakers. also i added a video of my head unit playing a dvd :D PLEASE forgive the picture and sound quality as i used my mobile phone lol tho believe me it was so loud i had neighbours coming out to see what all the racket/noise was about hahahahahaha may i say it sounds a zillion times better in person :P http://i918.photobucket.com/albums/ad27/the-man-that-can/060510124425.jpg http://i918.photobucket.com/albums/ad27/the-man-that-can/060510124619.jpg http://i918.photobucket.com/albums/ad27/the-man-that-can/060510131837.jpg http://s918.photobucket.com/albums/ad27/the-man-that-can/?action=view¤t=060510125504.flv
Post 313334 by watchmytracer on 2010-06-06 12:54:33
i managed to change over stereo fine just had to buy two sets of leads the ones of end of original leads then set to convert to stereo if anyone needs the codes let me know but works greaaaaaaat tray also fitted in with a click perfectly
Post 313371 by 850 chris on 2010-06-06 16:28:46
i changed my stereo and all i bought was a set of cheep iso leads and it works fine so it should just be a straight lead connection
Post 314704 by Rogerb on 2010-06-12 04:31:53
Hi, If you car is a late 850 or p1 X70 and you have a volvo amp (all sc 900/901 do) and option on others then you will need to remove the extra amp loom and connect to the original radio plugs . Some adactor leads do not have the split feed for the dash speakers ,but that said most ones for the volvos work ok. See two photos below 1st early type behind radio 2nd late type under right front seat. Regards Rogerb
