SC-805 not taking cd's
Post 310936 by jdavis on 2010-05-25 16:23:08
Hi guys, i ejected a disk from my CD player the other day, the eject mechanism seemed to continue running afterwards for a bit. now everytime i turn car on it runs like it's trying to eject disk. it won't pick up any CD's i try and put in it either. any tips?
Post 310943 by p fandango on 2010-05-25 16:34:20
my old mans is doing the same & read quite a few others doing the same, think there's a little plastic part inside that breaks
Post 311034 by princepugh on 2010-05-25 20:34:11
If this is the problem I think it is, there's a fix for it. Basically there's a tiny little micro switch near the CD mechanism which gets stuck in the wrong position but it can be fixed just by pushing it in again. I'll see if I can dig out the old article I followed to fix the SC on my phase 1 V70. ** update ** The fault I'm think of is on the SC816 unfortunately... http://www.volvospeed.com/Repair/sc816.htm
Post 311050 by gmain1967 on 2010-05-25 20:51:33
I was lead to believe that the SC805 is the same, and also has a microswitch, also located behind the rhs rail. If I get time tomorrow, I'll remove mine and have a look.
Post 311060 by princepugh on 2010-05-25 20:56:21
[quote=gmain1967;311050]I was lead to believe that the SC805 is the same, and also has a microswitch, also located behind the rhs rail. If I get time tomorrow, I'll remove mine and have a look.[/quote] Cool - defo worth a try then.
Post 311139 by jdavis on 2010-05-26 09:27:04
brilliant, thanks guys. will give that a try this morning.
Post 311143 by jdavis on 2010-05-26 09:42:03
brilliant stuff guys, a two minute job! save's me having to buy a new one.
