Post 300741 by madhouse on 2010-04-06 19:21:42
Just a quickie really, what is the correct diameter of pipe work for all the vacuum pipes/boost pipe etc is it 5mm id?
I'm tempted to replace all mine. Some look quite new - should they be clamped / tie wrapped? The newer ones appear to have no clips or clamps, is this ok? (I'm talking pipes from the Boost Control Solenoid back to the turbo / airbox and so on)
Finally does anyone have a diagram of all the various vac pipe locations just incase I miss some?
Cheers
Mark
__________________
Post 300813 by p fandango on 2010-04-07 05:16:57
you need some 4,5 & 6mm for the pipes. I always use jubilee clips to secure them. Internally braided fuel line is best as well to use instead of normal rubber or silicone, its alot strong & doesn't expand as easy
Post 300821 by madhouse on 2010-04-07 08:19:30
[quote=p fandango;300813]you need some 4,5 & 6mm for the pipes. I always use jubilee clips to secure them. Internally braided fuel line is best as well to use instead of normal rubber or silicone, its alot strong & doesn't expand as easy[/quote]
you can prob guess my next question.....
Where is the 4mm / 5mm / 6mm pipe.......
Post 300824 by nick on 2010-04-07 08:47:59
this might help a little although no reference to the diameter of hoses
