PCV help / explaination please...
Post 295986 by madhouse on 2010-03-16 14:11:31
Can anyone enlighten me on the PCV 'smokey dipstick' thing? I gather its possible to bypass it and have a catch tank? Would having the dipstick out a bit relieve any pressure? Image Just curious at this stage not yet double checked the beast. Cheers Mark
Post 296045 by martybelfastt5 on 2010-03-16 18:32:37
have seen these bypassed with the catch tank usually on cars running big bhp,,if you do have the smokey dipstick check your crank shaft oil seal,,oil dripping from the bottom of the gear box which leads to clutch replacement ect to get it fixed,,will eventually cause serious damage ie>the big ends to go if left
Post 296091 by madhouse on 2010-03-16 19:45:07
[quote=martybelfastt5;296045]have seen these bypassed with the catch tank usually on cars running big bhp,,if you do have the smokey dipstick check your crank shaft oil seal,,oil dripping from the bottom of the gear box which leads to clutch replacement ect to get it fixed,,will eventually cause serious damage ie>the big ends to go if left[/quote] Will have to has a nosey at the weekend, looks like it may have a smokey stick lol - bugga! Still ok to drive though aren't they?
Post 296157 by martybelfastt5 on 2010-03-16 21:47:36
sure just dont thrash her non stop,,,
