stutter back fire and general poor running on 460
Post 282090 by Mental Wealth Doctor on 2010-01-16 14:14:04
Its fine first thing when cold, but when it warms up it stutters under acceleration. its the 2.0 l injection. apart from plugs leads dizzy cap fuel filter. any surgestions
Post 282104 by Jamest5r on 2010-01-16 15:00:36
Ever changed/refurbed the injectors? mate, always a good place to start
Post 282105 by Mental Wealth Doctor on 2010-01-16 15:05:13
good call, James,
Post 282108 by Jamest5r on 2010-01-16 15:14:11
Don't know what injectors a 460 uses but ive got some spare orange ones??
Post 282115 by Mental Wealth Doctor on 2010-01-16 15:31:46
injectors look blue on the top, a mate has just said it might be lambada sensor, cos its only when its warm. hey thanks again for your help J, hopefully have these few jobs done by april, an myself and Griff will see you at avon.
Post 282269 by nobananas on 2010-01-16 23:15:39
Doubt it would be Lambda related, if it were you would get poor running at constant throttle speeds when the Lambda controls fueling, this would then clear under hard acceleration when the system no longer uses the Lambda sensor for fueling. Might be worth checking the ECT sensor seeing as it's only problematic when hot and being doubly sure that the leads etc are good, I have known pattern caps and rotor arms cause more problems than they solved !
Post 282348 by daveforber on 2010-01-17 14:45:46
Had this on my 480 and found I'd forgotten to reconnect the earth wire back to the dizzy. D'Oh.
