850 t5 speedo
Post 277178 by tiktauk on 2009-12-23 14:24:28
According to forums the 1996 model seems to be prone to a speedo fault. My speedo doesn't work and it does not appear to be due to mechanical failure. Are there any dealers out there that are suitably qualified to deal with the problem (some threads have suggested problems with the abs sensors etc).
Post 277179 by Tomcat on 2009-12-23 14:38:34
Do you have any other unrelated problems?... sometime it can be the ignition switch, try turning the key back slightly once the car is started.
Post 277320 by tiktauk on 2009-12-24 11:36:47
No other problems - that's why the speedo issue is bugging me. I'll try what you have suggested - thanks for the info.
Post 277322 by Vikingxl on 2009-12-24 11:40:10
I had issues with the speedo once in my V70 when i had a battery that was about to pack up
Post 277409 by cameron on 2009-12-24 21:00:02
May sound a bit obvious but have you checked the plugs onto the abs ecu :confused:
Post 277858 by tiktauk on 2009-12-28 17:09:18
Good shout - thanks for the info.
