Does a Road Angel work in Europe ?
Post 26334 by V8guitar on 2005-06-14 15:08:54
Anyone know if the Road Angel GPS bit works on the continent ( i.e. not the camera loaction and alerts stuff), particularly Germany ? Want to get a more accurate speed reading on the Autobahn's than the speedo if poss and might try to borrow a mate's if it does...anyone know ??
Post 26335 by Unknown on 2005-06-14 15:15:46
I would imagine not as it's GPS based and no doubt the map only covers the UK. Be careful when using detectors/scanners in Europe - in many countries, such as France, they are still very much illegal - 400 Euro on the spot fine.
Post 26338 by mraldonnelly on 2005-06-14 15:27:08
The camera warning won't as the Road Angel is only loaded with UK mapping software. However, I see no reason why it shouldn't show your speed as it bases this on the time taken to travel the distance travelled between GPS zaps (sorry, I don't know the technical term). However, it may need the mapping software as part of the calculations (I don't see any reason why it should but then I'm no techie). Regards Andy
Post 26339 by pzorb on 2005-06-14 15:32:58
Well my gps will give me the speed i'm going anywhere it can see the sky. Like it can tell me how fast i'm going in a plane across the atlantic if i put it by the window. So I don't see any reason why the Road Angel can't do the same, regardless of whether it knows it's in Germany or not (as in it knows where it is, but it doesn't know that where it is is called Germany - if it has no german maps or knowledge). Follow? :crazy: I can't see a reason why they'd only allow the speed feature to work if it knows it's on a road etc. Does that help? Borrowing a handheld GPS like a garmin eTrex or a magellan would certainly give you the information you require. Safe travels, Martin
Post 26340 by Unknown on 2005-06-14 15:34:06
I just had a quick word with a contact there. It won't work as it doesn't have the camera location software on the UK versions and there's no way of easily putting it on. The radar portion is the illegal bit not the gps bit. They don't advise you take it out of the UK because of this (I noticed they sell a non radar version now too)... However you could still use the GPS out and a PDA with mapping/camera software on if you wanted to I suppose. Andrew.
Post 26409 by GuyD5 on 2005-06-14 20:22:32
Hi Andrew I think you're missing the point a bit, Guy's asking whether the GPS bit of RA works .... and that should work anywhere it can pick up satellites and then calculate time and distance ... here or abroad .... surely it's only the database bit of RA which won't work .... but that won't stop the speed read-out will it ... so he can see how fast he's going on the autobhan :)
Post 26482 by Unknown on 2005-06-15 00:10:36
[QUOTE=GuyT5]Hi Andrew I think you're missing the point a bit, Guy's asking whether the GPS bit of RA works .... and that should work anywhere it can pick up satellites and then calculate time and distance ... here or abroad .... surely it's only the database bit of RA which won't work .... but that won't stop the speed read-out will it ... so he can see how fast he's going on the autobhan :)[/QUOTE] DOH! indeed.
Post 26519 by V8guitar on 2005-06-15 11:02:17
[QUOTE=GuyT5]Hi Andrew I think you're missing the point a bit, Guy's asking whether the GPS bit of RA works .... and that should work anywhere it can pick up satellites and then calculate time and distance ... here or abroad .... surely it's only the database bit of RA which won't work .... but that won't stop the speed read-out will it ... so he can see how fast he's going on the autobhan :)[/QUOTE] Thanks chaps - Guy you are truely in tune with me! And they say what's in a name..... Steve is hopefully bringing his handheld GPS unit as well, so we'll see what happens... If I can top 160, I'll be pleased....
Post 26521 by Unknown on 2005-06-15 11:12:14
Best check your tyres are rated for 160mph then :) Most won't be.
Post 26557 by V8guitar on 2005-06-15 15:34:19
I think they are rated for 180/190...can't remember. What is the code to check, is it the "v" part....
Post 26560 by Unknown on 2005-06-15 15:44:14
[QUOTE=V8guitar]I think they are rated for 180/190...can't remember. What is the code to check, is it the "v" part....[/QUOTE] Aye so my tyres "205/45/R17 W" W is the speed rating. http://www.blackcircles.com/general/speedrating
