turbo boost????
Post 270273 by p0xy on 2009-11-22 01:28:48
how much turbo boost psi, should be in 1st, 2nd, 3rd, 4th, 5th gear? on mine in 1st and 2nd is 10psi but in rest of gears its 12psi.. is this right? cheers
Post 270277 by Rnash2002 on 2009-11-22 07:52:43
[quote=p0xy;270273]how much turbo boost psi, should be in 1st, 2nd, 3rd, 4th, 5th gear? on mine in 1st and 2nd is 10psi but in rest of gears its 12psi.. is this right? cheers[/quote] If its all standard then seems a bit high,not by much though so wouldnt worry about it too much.
Post 270280 by Dangerous Dave on 2009-11-22 08:48:38
Boost is generally limited in lower gears to reduce wheelspin (although not sure how the ecu tells which gear its in, must go on speed and rpm)
Post 270295 by p0xy on 2009-11-22 12:40:29
aye mate its standard... just fixed a split pipe which was on it, must of been split since i got the car as it was only boostin about 8psi in 3rd 4th 5th
Post 270303 by p fandango on 2009-11-22 13:46:54
[quote=p0xy;270295]aye mate its standard... just fixed a split pipe which was on it, must of been split since i got the car as it was only boostin about 8psi in 3rd 4th 5th[/quote] mine did the same, i was running an MBC set at 14psi. When i fixed a couple of split pipes the boost then went upto 20.8psi, the standard ECU was still happy & no overboost so didn't bother lowering it lol
Post 270305 by C70 GTT5 on 2009-11-22 13:48:38
[quote=p fandango;270303]mine did the same, i was running an MBC set at 14psi. When i fixed a couple of split pipes the boost then went upto 20.8psi, the standard ECU was still happy & no overboost so didn't bother lowering it lol[/quote]nice a pre-done mod :)
Post 270329 by p fandango on 2009-11-22 16:12:37
[quote=C70 GTT5;270305]nice a pre-done mod :)[/quote] oh yes, the needle off the gauge is always nice to see lol Image
Post 271080 by kevt5 on 2009-11-26 00:26:20
what is standered psi for a standered 850 t5 ?
Post 271082 by cameron on 2009-11-26 00:28:41
IIRC 9.5psi, about 3/4 into the white bit of the guage :D
