Post 267950 by Johnny5 on 2009-11-07 00:49:51
I have just purchased a 40mm drop kit for the 850 from kalmar union (£107 inc vat)
Just a quick question on the rear springs, is it possible to compress and remove the rear springs without too much hassle? i.e not dropping the whole rear axle out????
J5
Post 267951 by Ed. on 2009-11-07 00:58:18
Which kit did you get? What are you doing with the old R springs? Could possibly be interested in them if they are in decent condition and at the right price.
Dunno if you can remove the springs in the way you suggested. Does your car have nivomats? That could make a difference to your answer.
Ed
Post 267952 by Johnny5 on 2009-11-07 02:02:31
[quote=Ed.;267951]Which kit did you get? What are you doing with the old R springs? Could possibly be interested in them if they are in decent condition and at the right price.
Ed[/quote]
Not got nivo's, and never fitted the springs cos they were standard ones, the guy who sold them on ebay didnt know what he was talking about lmao! anyway they were only £10 so nothing ventured etc etc lmao
Post 267956 by Wombatbomb on 2009-11-07 07:58:28
If it's the same as the rear of a C70 (which I believe it should be as the suspension on mine was previously fitted to an 850R) then you don't even need to remove the rear wheels, and certainly not need to compress the springs to fit them. The springs and shocks are mounted seperately on the rear of the car.
Post 267957 by Niles on 2009-11-07 09:10:38
rear spring removal...... undo the nut on the bottom of the mount, undo the nut holding the bottom of the shock to the rear subframe. Release the shock from the bottom, after wiggling & jiggling the spring should come out without spring compressors etc. Refit is also possible without compressors. Did mine last week.
Post 267977 by Al115 on 2009-11-07 12:32:32
Yep - as the man says. Easy as pie to do the rears :)
Post 269316 by Johnny5 on 2009-11-15 22:57:10
Thanks guys! Yeah job done! Undone the lower shock nut, jacked up the body at the back and slipped them out! Nice and easy! Not so for the fronts grrrrrrrr i HATE using spring compressors period! But anyway, fronts done now! Sits much better now! And it clears the speed bumps im my area 2!
I do have now though 2 whole sets of springs for an 855, so any offers for them????
Regards
J5
