Post 267413 by Johnny5 on 2009-11-03 18:37:53
Driving home tonight, my instrument illum went out! Then came back on, and then went off again.... Didnt seem to be "bumps" related, just seems to have a mind of its own.......
Anyone else had this prob, going to have to wait till the weekend to have a look :(
Post 267420 by splatt on 2009-11-03 19:55:11
This is an ignition barrel thing if I remember right. Slight wear causes a loss in connection on the multiswitch attached at the back.
Post 267421 by Storm-Troll on 2009-11-03 19:55:44
Sounds like you have a short somewhere. if it was only 1 bulb doing it. id say it was a lose bulb in its holder but if teh whole lot age doing it.. sounds like maybe you have a short somewhere. Or maybe some water has got into the wiring somewhere causing it to bridge and short out....
Post 267440 by Tomcat on 2009-11-03 21:26:27
Does sound like it's either a knackered ignition switch or a faulty dimmer switch, next time it does it try turning the key back just a fraction, failing that give the dimmer a wiggle.
