Volvo 855 rear lamp replacement
Post 266699 by ken10 on 2009-10-29 05:07:15
My 855 rear lamps have turned whitish. Have just purchased new lamps. How do I remove the old lamps and replace them with the new ones? Thanks.
Post 266702 by carl_t5 on 2009-10-29 07:19:33
855 the estate? If so remove speaker in the pillar and lower plastic trim (need to move carpet to gain access if i remember right), remove upper bulb holders then light cluster, i used 8 or 10mm deep socket, can be a pain with 2 or 3 nuts (its been a while since done it). Remove lower bulb holder then remove nuts again, only this time much more of a pain to get nuts out. Then just refit new ones. Hope this helps.
Post 266712 by cherry1809 on 2009-10-29 09:08:41
There's a couple you won't get to with a socket, So if you have to use a spanner, Trust me and tie a piece of string to the end of it.
Post 266714 by flyingbrick on 2009-10-29 09:27:20
Hi. I managed to get to all the nuts with a socket and some wobbly extesion bars (right pain in in butt):mad111: Its a fiddley job but not to hard. One thing I do remember is when you put the new lamps on put the bottom ones on first as the top ones over lap the bottom. If you put the top ones one first you cant get the bottom ones on.:slap: That did not make me laugh having to loosen the top ones:cuckoo:
