Towing and remaps
Post 245845 by Welshlou on 2009-07-30 20:47:56
I tow a caravan a lot with my car and I've been told that a remap would cause problems for the turbo whilst driving at about 70 mph with a caravan on the back, as the revs would be higher that they would normally (without a caravan), which would affect the operation of the turbo. I'm not sure what people mean by this, but has anyone else had problems towing with remaps? Cheers...
Post 245856 by Welshlou on 2009-07-30 21:15:16
[quote=Fletchv70RAWD;245846]Mine has been re-mapped and I have had no problems with towing for 4 years. Your main problem may be with the law if you tow at 70mph !!! :)[/quote] Ha ha... that might be why I have 9 points then!!
Post 245864 by Pliskin on 2009-07-30 21:27:45
I used to, albeit for a short while, tow a small caravan with my 854, which has got the 280 map and didn't find any problems, in fact one of the reasons I got the map in the first place was to get a bit more low down pull. I suppose it depends on where the grunt comes in on the map of choice and your right foot, but as I say I didn't have any problems. What I did do as a precaution because mine is an auto was to ask his Wobblyness to fit one of his auto fluid additional coolers to it. This also gave me the time to take Dave's carriage at the time,"Rayanna" ( have I spelt it right Dave?) for a little tootle around the block and very nice it was too. Regards,
Post 245869 by AlanG on 2009-07-30 21:49:52
[quote=Fletchv70RAWD;245846]Mine has been re-mapped and I have had no problems with towing for 4 years. Your main problem may be with the law if you tow at 70mph !!! :)[/quote] Exactly bud,careful what you type on here. You'd be surprised who is watching..
Post 245870 by Unknown on 2009-07-30 21:52:38
[quote=Welshlou;245845]I tow a caravan a lot with my car and I've been told that a remap would cause problems for the turbo whilst driving at about 70 mph with a caravan on the back, as the revs would be higher that they would normally (without a caravan), which would affect the operation of the turbo. I'm not sure what people mean by this, but has anyone else had problems towing with remaps? Cheers...[/quote] I dont quiet understand the logic of the revs being higher after a remap, unless obviously your driving in a lower gear which you wouldnt have to do after a remap as you would have more torque. So the only way I can see the revs being higher is if you change your gear ratio's But then again I could be talking balls lol... did the person who told you this explain why the revs would be higher?
Post 245876 by Welshlou on 2009-07-30 21:55:59
[quote=Davew;245870]I dont quiet understand the logic of the revs being higher after a remap, unless obviously your driving in a lower gear which you wouldnt have to do after a remap as you would have more torque. So the only way I can see the revs being higher is if you change your gear ratio's But then again I could be talking balls lol... did the person who told you this explain why the revs would be higher?[/quote] I think they meant the revs would be higher at 60(!) because the caravan is on the back, meaning you need more power to achieve the same speed.
Post 245877 by cornclose on 2009-07-30 21:57:45
No problems towing with my V70 which has the RICA 310 on it. I also towed before I had the remap too, and all I can say is that it tows much better mapped than not. One thing that should help massively when towing is the water injection system I've just fitted, which should help keep intake temperatures to a minimum as when towing you tend to be using boost more often than when not towing, so power drop off is more noticable when towing, especially in the summer months when ambient temperatures are higher. In short, a remap can only help rather than hinder when towing...
Post 245881 by Unknown on 2009-07-30 22:02:35
[quote=Welshlou;245876]I think they meant the revs would be higher at 60(!) because the caravan is on the back, meaning you need more power to achieve the same speed.[/quote] OK I still dont understand the logic, (maybe i am being stupid) Take for example a push bike. If you have a skinny guy pedaling at one turn a second in forth gear, then he gets off and a body builder gets on and pedals in the same gear at one turn a sec, they will both be doing exactly the same speed and exactly the same revolutions. It would just be easier for the guy with more power. That is why I cannot understand why if you give your car more power it would rev higher?
Post 245885 by cornclose on 2009-07-30 22:06:06
I think maybe he means the engine load is higher, which of course it will be, but that isn't a problem if you're in the correct gear and use the power band available etc. As I said, no issues at all, much better towing with the remap, but no real issues without it either.
Post 245887 by Welshlou on 2009-07-30 22:12:24
[quote=Davew;245881]OK I still dont understand the logic, (maybe i am being stupid) Take for example a push bike. If you have a skinny guy pedaling at one turn a second in forth gear, then he gets off and a body builder gets on and pedals in the same gear at one turn a sec, they will both be doing exactly the same speed and exactly the same revolutions. It would just be easier for the guy with more power. That is why I cannot understand why if you give your car more power it would rev higher?[/quote] Isn't it a question of revs per minute, rather than just revolutions. ie the engine would need to rev more times per minute to achieve 60 mph, with more load.
Post 245889 by Welshlou on 2009-07-30 22:15:24
Thanks for the info guys, I guess the remap will be better for towing so i'll have no issues when i get it done.
Post 245891 by Unknown on 2009-07-30 22:23:45
[quote=Welshlou;245887]Isn't it a question of revs per minute, rather than just revolutions. ie the engine would need to rev more times per minute to achieve 60 mph, with more load.[/quote] No it wouldnt. I just think you are concerning yourself over something you dont understand and are worrying about nothing. rev per minute is the same as revolutions. if your engine revs more you go faster. just watch your rev counter. if you put a 747 on the back you will still be doing exactly the same revs at the same speed as when you didnt have it on. (if you where in the same gear) The only thing that will effect the revolutions per minute at a certain speed is the gear you are in. If you do 2000 rpm in top gear on the motorway at 60 mph, you will still do 2000rpm on the motorway in top gear if you have the caravan on the back. you will require more power to pull the caravan, (more fuel) due to the increased weight. (imagine riding a bike up hill you have to push harder to maintain the same speed).
Post 245895 by Welshlou on 2009-07-30 22:34:41
[quote=Davew;245891]No it wouldnt. I just think you are concerning yourself over something you dont understand and are worrying about nothing. rev per minute is the same as revolutions. if your engine revs more you go faster. just watch your rev counter. if you put a 747 on the back you will still be doing exactly the same revs at the same speed as when you didnt have it on. (if you where in the same gear) The only thing that will effect the revolutions per minute at a certain speed is the gear you are in. If you do 2000 rpm in top gear on the motorway at 60 mph, you will still do 2000rpm on the motorway in top gear if you have the caravan on the back. you will require more power to pull the caravan, (more fuel) due to the increased weight. (imagine riding a bike up hill you have to push harder to maintain the same speed).[/quote] Gotcha... Your right about me not understanding it, but i do now cheers!! Like you say, nothing to worry about then!
Post 245901 by AlanG on 2009-07-30 22:58:41
Just get it mapped...........you will never regret it..
Post 245908 by thebadger on 2009-07-30 23:27:25
The idea of trying to use the turbo when towing is mental anyway! You'll bend the tow hitch or the tow ball frame using all the torque! Remember, gentle revs, slow up to speed. (you're driving a volvo... and you're towing a caravan!) Take the proper precautions. Slippers on, flatcap straight & pipe unlit (for H&S reasons!). ** Serious now* The main issue is strain on the gear box & clutch. The engine (providing it's in good nick & has oil in it!) will not bat an eyelid at a caravan. Your clutch should be in good order & you really should do a gearbox oil change! Other than that... observe the speed limits, try & get a set of volvo's own tow mirrors (awesome stuff them!) and try not to drive within.... oh about 30 miles of me! :rolleyes: The turbo may suffer if you try to boost the car for long periods under high revs vs high strain. But only from overheating!
Post 245966 by dave stew on 2009-07-31 07:44:49
What's all this talk about clutches? I thought most of the members on here are part of the slushbox brigade!
Post 245977 by thebadger on 2009-07-31 08:37:05
I'm just assuming that someone might have bought at least ONE manual tranny in a P2! But the box oil is probably worth a check... level & condition.
Post 245980 by p fandango on 2009-07-31 08:45:12
[quote=thebadger;245977]I'm just assuming that someone might have bought at least ONE manual tranny in a P2![/quote] mines got a proper gearbox :hail:
Post 245982 by thebadger on 2009-07-31 08:46:52
In some ways I wish I did have a manual... But I'm a lazy sod, so I'm glad I have an auto!
Post 245990 by v70torslanda on 2009-07-31 09:30:17
[quote=dave stew;245966]What's all this talk about clutches? I thought most of the members on here are part of the slushbox brigade![/quote] Secret pedal envy?
Post 245998 by dave stew on 2009-07-31 11:14:35
Aren't you at work today?
Post 246005 by thebadger on 2009-07-31 11:31:23
Could be worse, it could have a mad American style hand/emergency brake! 4 pedals would really get you down!
Post 246022 by dave stew on 2009-07-31 12:29:22
[quote=thebadger;246005]Could be worse, it could have a mad American style hand/emergency brake! 4 pedals would really get you down![/quote] Very much designed with autos in mind - Merc has persisted with this strange arrangement with the new E Class.
Post 246027 by lance on 2009-07-31 12:51:14
Ohh dear I didnt realize we had so many caravaners amongst us, Im sure a remap would help, more pulling power but you dont want to go fast with a caravan on anyway, Ive seen turned over Landrovers on the A1 and they are slower and much heavier than T5s. If I had my way I would take a hint from the Isle of man and ban the things. Campers on the other hand and modified horse boxs and bus's are cool!
Post 246033 by thebadger on 2009-07-31 13:29:13
Yeah, losing it while towing would rate as a major frightener! Did you ever see TG trying to break the world record speed for towing a van? I've also seen a few bent tow bars due to excessive acceleration while towing. Not a very cheap or funny thing to have to fix!
