The final choice so which one??
Post 245136 by Welshlou on 2009-07-28 15:50:36
Right guys and gals, I'm gonna spend the cash on an air filter tomorow so which is it to be? From what I've been told, it's been narrowed down to these two. 1. K&N Panel Filter - http://www.knfilters.com/search/product.aspx?Prod=33-2670 2. BSR Opti Flow Cone Filter - http://www.bsruk.co.uk/articles.asp?id=93 My car is a 2000 V70 T5 P2 and if it helps I plan to do a remap of some kind (probably RICA) and an exhaust change (probably Ferrita) in the near future. Cheers in advance for the help...
Post 245142 by Baj on 2009-07-28 16:04:18
I have one of these (http://www.pipercross.net/panelfilters/product.asp?m1=48&m2=666&app=3257) going spare. It is used but good (oiled up ready to go). I bought it from someone here but never used it as I have an ITG as well. I paid £30odd quid for it. Make me an offer if interested.
Post 245146 by thebadger on 2009-07-28 16:21:03
I've had both K&N panel & the BSR optiflow fitted. The BSR is different sounding, but has the ability to hump your MAF, however the K&N is just a much improved version of the original which will aid the performance without changing the "stock" look under the hood. It's a choice thing, but the K&N (or Baj's pipecross panel) will be much cheaper!
Post 245149 by Welshlou on 2009-07-28 16:30:04
[quote=thebadger;245146]The BSR is different sounding, but has the ability to hump your MAF[/quote] Hey Badger - please could you tell me what this means... sorry - I'm not that technical when it comes to engines! Cheers...
Post 245151 by Welshlou on 2009-07-28 16:34:50
[quote=Baj;245142]I have one of these (http://www.pipercross.net/panelfilters/product.asp?m1=48&m2=666&app=3257) going spare. It is used but good (oiled up ready to go). I bought it from someone here but never used it as I have an ITG as well. I paid £30odd quid for it. Make me an offer if interested.[/quote] Hi Baj - Many thanks for the offer, I might be interested - I'll let you know when I've had a few more replies on what the best option is (i.e. cone or pannel). Cheers...
Post 245194 by thebadger on 2009-07-28 18:55:56
It's louder. Lots louder, but at the same time you need to think of the cost & that the system has a limited heat shield. Every time you stop the engines heat will flow round the sheild & heat the air into the engine, turbo & the MAF. The MAF is a hot wire sensor, which means that if you put lots of hot air through it then it will draw even more air to compensate, which will result in a higher idle speed & burn more fuel. It sounds like darth vader having an asthma attack, but it's really a touch counter productive! As I said before it's a matter of choice. I'd pick the panel filter! (and have!)
Post 245216 by mexybhouy on 2009-07-28 19:36:22
I have tried both, the k&n panel filter was meant to make it breath easier! did'nt really notice any difference to be honest! it got really dirty quite quickly and needed re oiling far more than the recomended intervals, (anyone else find this)? now i have the bsr one fitted and all i can say is the noise is superb feels slightly more responsive and looks great! but depends on your choice or budget! let's face it in our climate, under bonnet tems don't make much difference when parked up because once you get going again the air starts to flow again m8!
Post 245309 by DuncVolvoTurbo on 2009-07-28 23:39:06
I've got a Pipercross panel filter in mine, and can't fault it one little bit. I eventually came to the decision on getting one from reading through reviews on here and VOC.
Post 245357 by Dangerous Dave on 2009-07-29 08:36:15
I've just bought an ITG filter for mine, £48 delivered. Gonna see what its like
Post 245361 by thebadger on 2009-07-29 08:48:41
I'm personally very fond of my K&N, it's yet to give me any hassle.
Post 245368 by irf on 2009-07-29 09:32:02
[quote=thebadger;245194] The MAF is a hot wire sensor, which means that if you put lots of hot air through it then it will draw even more air to compensate, which will result in a higher idle speed & burn more fuel.[/quote] if it draws more air in wouldn't it run leaner(less fuel)? If i was making the choice i'd go for the BSR. As alluded to above, there may be temp issues when in traffic or in a queue at santa pod but when moving it can't be an issue. Can it? Love the noise it makes but thats subjective.
Post 245370 by p fandango on 2009-07-29 09:43:30
tbh i don't know how good/bad the standard set-up is, but the factory set-up is always a comprimise i prefer cone filters myself. I've had many different intake set-ups, i got my fastest time at Santa pod using an open cone
Post 245372 by thebadger on 2009-07-29 09:46:39
I liked the sound it made too (BSR) that's why I kept hold of it! I think a K&N panel is the best of both worlds!
Post 245391 by Filterlab on 2009-07-29 11:18:50
Number 1 would be my choice out of the two, but a sealed cold air kit would be my overall choice.
Post 245397 by Dangerous Dave on 2009-07-29 11:25:04
I was thinking k&N too, but I read post #1 in this thread http://rcolt.com/showthread.php?p=51919
Post 245417 by p fandango on 2009-07-29 12:06:32
[quote=bomb192uk;245397]I was thinking k&N too, but I read post #1 in this thread http://rcolt.com/showthread.php?p=51919[/quote] i've had K&N before & tbh wasn't impressed, even going from K&N to pipercross gave a noticable improvement
Post 245425 by thebadger on 2009-07-29 12:34:01
I think the difference between stock filter & any uprated filter is noticable, but from different types of uprated panel filters, be they K&N, Pipercross or any other is negligable at best. Baj has a pipercross up for grabs, I'd say grab it! The Cone filters are good for the loud audio of suction from the car, but will always suffer from heat while the car is sitting at lights etc. There will always be opinions to state which is best for the performance, but best to stick to your budget & get the best value possible for the bucks! I think you really should be looking for exhaust upgrades, so a bit of money saved buying the filter is more you can chuck at the tailpipe! Just my opinion, but there's very little in all types of filter (avoiding the OEM paper) just the costs involved!
Post 245427 by paulsimon on 2009-07-29 12:39:03
[quote=Baj;245142]I have one of these (http://www.pipercross.net/panelfilters/product.asp?m1=48&m2=666&app=3257) going spare. It is used but good (oiled up ready to go). I bought it from someone here but never used it as I have an ITG as well. I paid £30odd quid for it. Make me an offer if interested.[/quote] PM sent.
Post 245431 by thebadger on 2009-07-29 12:48:00
^ Cheeky! But fair play!
