Going faster (on a budget...)
Post 237791 by BigV on 2009-06-25 05:26:44
I have just picked up my new 850t5 (auto), it seems to be running great and it already has an MBC (powertek) fitted with possible?? remap, I was told by the previous owner that it was rolling roaded at 264bhp, how accurate that is I don't know..................................... what I can say is that it goes 0 to 50 faster than my RICA'd c70 did, but from 55mph onwards it feels a bit gutless to be honest. I'm expecting some cash later this year and I was thinking about trying to squeeze a bit more out of her, but I'm on a budget of 1 to 1.5k maximum. My plan was to get a full free flowing exhaust (inc downpipe and decat or race cat), after that I am totally clueless! Any suggestions or advice?
Post 237793 by JelT5 on 2009-06-25 06:26:50
Deffo the exhaust: according to JT exhausts, a full system incl. race cat (or de-cat) will give you an extra 5-10% more power. Thats about the limit of my knowledge apart from reverse intercooler pipework, R manifold, bigger turbo (18T or 19T), bigger intercooler etc etc IPD are a good source of information for stage 3 check out the link: [ame="http://www.youtube.com/watch?v=dTkyuucfeWY"][COLOR="Black"]IPD Stage 3[/COLOR][/ame]
Post 237802 by BigV on 2009-06-25 08:50:01
[quote=JelT5;237793]Deffo the exhaust: according to JT exhausts, a full system incl. race cat (or de-cat) will give you an extra 5-10% more power. Thats about the limit of my knowledge apart from reverse intercooler pipework, R manifold, bigger turbo (18T or 19T), bigger intercooler etc etc IPD are a good source of information for stage 3 check out the link: [COLOR="Black"]IPD Stage 3[/COLOR][/quote] useful link thanks. I think bigger turbos are going to be out of my budget to be honest, as I would need to pay someone to do the fitting of these items as well. I also need to find out if the car is remaped or not - I fitted a boost gauge this morning and with the MBC she is holding 12psi and peaking at 14 to 15psi on upshifts (autobox)..... the ECU doesn't look as though it has been tampered with, but the MBC is setup 'inline' with the factory BCS which is something I have never seen before. Is there any easy way to tell? I might just go with a full exhaust system and a remap or rolling road setup and leave it at that?
Post 237834 by dooby on 2009-06-25 11:37:25
Hiya, £500ish race cat downpipe £300ish 2.5" cat-back exhaust £50ish free flowing panel air filter And spend the rest on a map would be my advice I think. Gets you somewhere around the £1000 mark, leaving some spare for fitting. Keep an eye on the auto fluid condition if you're upping the power. I fitted an additional auto cooler to mine to help the longevity of the box. You can flush auto fluid yourself I suspect, and the fluid is in the region of £160 from Volvo if you want to go genuine (I did). HTH, Pete
Post 237837 by JelT5 on 2009-06-25 12:05:22
[quote=BigV;237802]useful link thanks. I think bigger turbos are going to be out of my budget to be honest, as I would need to pay someone to do the fitting of these items as well. I also need to find out if the car is remaped or not - I fitted a boost gauge this morning and with the MBC she is holding 12psi and peaking at 14 to 15psi on upshifts (autobox)..... the ECU doesn't look as though it has been tampered with, but the MBC is setup 'inline' with the factory BCS which is something I have never seen before. Is there any easy way to tell? I might just go with a full exhaust system and a remap or rolling road setup and leave it at that?[/quote] Best way to tell about a remap is check the ECU- theres usually a sticker on the side somewhere- mine has a RICA sticker on it. I run an HLM (RICA) 304 map with catback exhaust and BSR air filter. Works very well on my auto T5. The boost you're getting sounds fine for a non mapped car. I was getting similar peaks to you when I was running just an mbc. The map really helps as the car now holds peak boost at 1.2+bar (nearly 18psi) with no afr problems. I do still use my mbc, but only at the strip due to the peak boost holding at 1.4bar in top lol. It's awesome, but worrying as rod failure could occur :( Got to say I haven't seen an mbc inline with the BCS, but if it works ok then leave it be! Try HLM and JT exhausts for remap and exhaust: [COLOR="Black"]HLM LINK[/COLOR] [COLOR="Black"]JT LINK[/COLOR] Should be well within your budget to get both of these and leave you some dosh for a coupla other bits, r/r etc :)
Post 237868 by p fandango on 2009-06-25 14:25:08
AlanG is running his MBC inline. Personally as running it that way is just a ECU controlled bleed valve & a MBC i prefer to ditch the BCS, but think he was having trouble getting the boost high enough to see if you are remapped replace the MBC with straight pipe & see what it boosts to, if its more that 3/4 in the white then its remapped
Post 237911 by AlanG on 2009-06-25 17:55:24
True Ped,excluding the BCS on my car dropped the boost considerably. Remember posting on here that I took my advice from Hamish as I am no expert with turbo cars. Now after some stage by stage adjustment of the MBC it takes the dash guage off the white with no problems this far and a reliable 30mpg. But mine has the re-map.
Post 238273 by BigV on 2009-06-27 10:34:22
Thanks guys..... I think I will stick to the basics first........ get the exhaust done then look at possible remaps. The thing is I actually had my previous C70 remapped and it was slower off the line than the MBC....... so I might like to get it remapped and use the MBC at the same time..... dunno, I will see how it goes one she has been serviced and had the downpipe/cat and exhaust done.
Post 238275 by p fandango on 2009-06-27 10:55:42
[quote=BigV;238273]The thing is I actually had my previous C70 remapped and it was slower off the line than the MBC....... so I might like to get it remapped and use the MBC at the same time..... dunno, I will see how it goes one she has been serviced and had the downpipe/cat and exhaust done.[/quote] MBC's are brilliant & alot more aggressive than a remap as always please be very careful running a remap & a MBC, the remap will raise/remove the standard maps overboost limit so if you do go too mad with the MBC it will let you bend a con-rod
Post 238276 by Filterlab on 2009-06-27 11:04:43
[quote=p fandango;238275]...if you do go too mad with the MBC it will let you bend a con-rod[/quote] And nobody wants one of them! :jaw:
Post 238278 by p fandango on 2009-06-27 11:13:56
[quote=Filterlab;238276]And nobody wants one of them! :jaw:[/quote] no not really, fitting a bigger stereo to cover the noise of the rattling doesn't do the preformance much good lol
Post 238285 by BigV on 2009-06-27 13:17:44
[quote=p fandango;238275]MBC's are brilliant & alot more aggressive than a remap as always please be very careful running a remap & a MBC, the remap will raise/remove the standard maps overboost limit so if you do go too mad with the MBC it will let you bend a con-rod[/quote] Ok.... I mean I could just run the MBC on it's own but there is no way to know if I am getting enough fuel in is there? At least the remap (I assume) gives a richer mix of fuel?
Post 238288 by p fandango on 2009-06-27 13:43:19
[quote=BigV;238285]Ok.... I mean I could just run the MBC on it's own but there is no way to know if I am getting enough fuel in is there? At least the remap (I assume) gives a richer mix of fuel?[/quote] you could get the AFR's checked on a rolling road if your concerned, but i've been running an MBC (or EBC) for about 7years on the stock ECU with no issues & i've been running alot higher boost than recommended (20.8psi) the remap will increase the fuelling, but it still doesn't mean it will be correct for the MBC as its mapped for the boost increase the remap has set using the BCS not any other boost devices as your using the MBC inline with the BCS the slower duty rate of the BCS after the remap (ie to increase boost) will raise the boost even higher, so please make sure you've got an aftermarket boost gauge so you can adjust it to compensate
Post 238292 by Filterlab on 2009-06-27 14:12:12
[quote=p fandango;238278]no not really, fitting a bigger stereo to cover the noise of the rattling doesn't do the performance much good lol[/quote] LOL! :hilarious That's the method employed by the standard 19 year old I believe.
Post 238311 by p fandango on 2009-06-27 15:36:07
[quote=Filterlab;238292]LOL! :hilarious That's the method employed by the standard 19 year old I believe.[/quote] been there done that :doh: Image
Post 238623 by BigV on 2009-06-29 10:34:32
[quote=p fandango;238288]you could get the AFR's checked on a rolling road if your concerned, but i've been running an MBC (or EBC) for about 7years on the stock ECU with no issues & i've been running alot higher boost than recommended (20.8psi) the remap will increase the fuelling, but it still doesn't mean it will be correct for the MBC as its mapped for the boost increase the remap has set using the BCS not any other boost devices [/quote] On that note can anyone recommend an rolling road in the midlands / coventry area?
Post 238631 by JelT5 on 2009-06-29 11:28:22
Power Staiton- Tewkesbury; have a mate who works there. [COLOR="Black"][SIZE="4"]LINK[/SIZE][/COLOR] Maybe that's too far for you- good team there though!
Post 238669 by p fandango on 2009-06-29 14:41:01
[quote=BigV;238623]On that note can anyone recommend an rolling road in the midlands / coventry area?[/quote] i'm going to use TVR power on the Longford Road, mate of mine who drag races VW's uses them for all his work & always has a good work to say
Post 238686 by BigV on 2009-06-29 17:10:29
[quote=p fandango;238669]i'm going to use TVR power on the Longford Road, mate of mine who drag races VW's uses them for all his work & always has a good work to say[/quote] Assuming that an auto can go on a dyno? Might be a bit embarrassing taking a battered old volvo down a TVR specialist though LOL.
Post 238691 by dooby on 2009-06-29 17:24:42
I had mixed results taking my auto on dynos - two were fine, two couldn't do it. In each case I rang ahead to check it would be fine, but still ended up with 2 wasted journeys :-( HTH, Pete
Post 238692 by p fandango on 2009-06-29 17:25:41
[quote=BigV;238686]Assuming that an auto can go on a dyno?[/quote] it is complicated but i have seen figures from auto's, i'm not sure if TVR power do them tho tbh
please if my mate can take VW's there then i'm sure we can take Volvo's, they are expanding & more than happy to medal with other makes. Just turn up on a rainy day, being TVR specialist i'm sure there not used to cars being able to get there in the bad weather lol Image mates VW van (Vanarchy), i'm sure TVR power did all the MSD ignition programming & helping him set the nitrous up
Post 261801 by BigV on 2009-10-02 13:26:38
Bump, any other suggestions? My budget is going to be 1.5k I think, should be ready in the next 3 weeks or so. Gotta do some basic service stuff first... she needs PCV, Front brakes and an oil leak fixing (think the leak is just from the sump plug though, so just an oil&filter with a new plug and washer... £40 maybe). Apart from that it is all going on performance, although I now have no where to work on the car so I will be having to pay to get parts fitted. Do places like kwikfit fit downpipes or is it a garage job?
Post 261804 by Ed. on 2009-10-02 13:41:17
There is a specialist exhaust centre in Nuneaton called Custom Chrome Racing. They will be able to fabricate a hi flo cat and downpipe for your car. They did the cat on mine for under 200 notes. Ed
Post 261805 by p fandango on 2009-10-02 13:55:17
[quote=Ed.;261804]There is a specialist exhaust centre in Nuneaton called Custom Chrome Racing. They will be able to fabricate a hi flo cat and downpipe for your car. They did the cat on mine for under 200 notes.[/quote] i got my air filter & oil catch tank from them, they also did the welding on my RIP kit
Post 261833 by BigV on 2009-10-02 15:17:00
[quote=Ed.;261804]There is a specialist exhaust centre in Nuneaton called Custom Chrome Racing. They will be able to fabricate a hi flo cat and downpipe for your car. They did the cat on mine for under 200 notes. Ed[/quote] Sounds interesting.... the one from MTE/kalmar union is £580 for the downpipe+cat plus £380 for the exhaust..... plus delivery I assume, plus fitting too.
Post 261879 by Jamest5r on 2009-10-02 18:51:29
Mate have a call around, you should be able to get a full 3" s/s exhaust with 100 cell race cat made and fitted from CCR for alot less than what your thinking, also there is a place over dudley way M5/J2 cant remember the name someone will though
Post 261884 by BigV on 2009-10-02 19:16:51
[quote=jamest5r;261879]Mate have a call around, you should be able to get a full 3" s/s exhaust with 100 cell race cat made and fitted from CCR for alot less than what your thinking, also there is a place over dudley way M5/J2 cant remember the name someone will though[/quote] Yeah,I will do that next week when they are open...... I just hate phoning these places as I find they either wanna rip you off or aren't interested unless you have money to burn lol. 3'' all the way through might be noisy. :dgrin: , I noticed a lot of guys have gone for a 3'' DP with race cat/decat and then a 2.5inch catback?
Post 261885 by danny-R on 2009-10-02 19:20:50
i got a 2 1/2 inch downpipe, with no cat, only 1 silencer from LONGLIFE dealer in leeds, all in if i remember rightly was £420 which i think is fair price. i'd get a few quotes 1st as i did. if i were you i would go for 2 silencers as i only have one, and i wish i had the money to get another one fitted. don't get me wrong it sounds awesome but i think i want to go stealth now.
Post 261890 by BigV on 2009-10-02 19:57:26
[quote=danny-R;261885]i got a 2 1/2 inch downpipe, with no cat, only 1 silencer from LONGLIFE dealer in leeds, all in if i remember rightly was £420 which i think is fair price. i'd get a few quotes 1st as i did. if i were you i would go for 2 silencers as i only have one, and i wish i had the money to get another one fitted. don't get me wrong it sounds awesome but i think i want to go stealth now.[/quote] Now that is a bargain.... do you have to mess about for the MOT or does it run clean enough to pass with no cat? I'll go for 2 boxes then..... I don't want my ears to bleed, although a bit more growl when giving it some stick would be nice. Probably go for a 3'' turbo back with race cat and 2 silencers, airfilter and then look for a remap. If I can get the exhaust as cheap as what you guys are saying then I might have enough for some 17'' alloys too.
Post 262327 by smithy on 2009-10-05 09:16:54
[quote=BigV;261884]Yeah,I will do that next week when they are open...... I just hate phoning these places as I find they either wanna rip you off or aren't interested unless you have money to burn lol. 3'' all the way through might be noisy. :dgrin: , I noticed a lot of guys have gone for a 3'' DP with race cat/decat and then a 2.5inch catback?[/quote] hello mate the is alot you can do for that money on your car .i would think about a good second hand or recon 16t or 19t turbo with 3in outlet if possible then either get a second hand downpipe off a s or v70 p1 me7 and run a cat back 3in ss exhaust,and remap should be able to get all this done for around 1200 max .i had an 3in exhaust with race cat built by ccr nuneaton and the quality is good and they build there own boxes too because they manufactor too .
Post 262414 by p fandango on 2009-10-05 16:01:02
[quote=BigV;261884]I noticed a lot of guys have gone for a 3'' DP with race cat/decat and then a 2.5inch catback?[/quote] thats what the Ferrita system for the 850 is, you can get a 3" full Ferrita system to fit but most stick with the 2.5". I was quite happy to stick with 2.5" as i've got the bypass valve so it doesn't matter whats after it & it fits onto the original backbox i'd got HLM were the cheapest when i was looking
Post 262428 by BigV on 2009-10-05 17:15:29
[quote=smithy;262327]hello mate the is alot you can do for that money on your car .i would think about a good second hand or recon 16t or 19t turbo with 3in outlet if possible then either get a second hand downpipe off a s or v70 p1 me7 and run a cat back 3in ss exhaust,and remap should be able to get all this done for around 1200 max .i had an 3in exhaust with race cat built by ccr nuneaton and the quality is good and they build there own boxes too because they manufactor too .[/quote] What sort of price did you pay for the Ccr exhaust? You reckon £1200 ish for the parts or is that with fitting too? can't do my own work because I know nothing beyond basic servicing lol
Post 262431 by p fandango on 2009-10-05 17:22:55
[quote=BigV;262428]You reckon £1200 ish for the parts or is that with fitting too? can't do my own work because I know nothing beyond basic servicing lol[/quote] Volvo main stealer charged me £232 to fit my 19t, manifold & 3" downpipe
Post 262445 by PaulZX on 2009-10-05 17:47:53
I worked on a budget of less than £1500 and I started in exactly the same spot you are in. It took me from march until late May to get the work done. check out my thread for the details.... http://www.vpcuk.org/forums/showthread.php?t=21419
Post 262966 by smithy on 2009-10-07 14:42:39
[quote=BigV;262428]What sort of price did you pay for the Ccr exhaust? You reckon £1200 ish for the parts or is that with fitting too? can't do my own work because I know nothing beyond basic servicing lol[/quote] where are you based mate
Post 263041 by BigV on 2009-10-07 18:52:48
[quote=smithy;262966]where are you based mate[/quote] Coventry. [quote=jamest5r;261879]Mate have a call around, you should be able to get a full 3" s/s exhaust with 100 cell race cat made and fitted from CCR for alot less than what your thinking, also there is a place over dudley way M5/J2 cant remember the name someone will though[/quote] CCR quoted me £650 to £750 for a full 3inch s/s system with 100cell cat.... ball park figure. Fitted including vat. Much better than I thought.
Post 263042 by p fandango on 2009-10-07 18:54:33
[quote=BigV;263041]Coventry.[/quote] oh dear, i'm in Cheylesmore
Post 263059 by cornclose on 2009-10-07 20:01:56
I was in Coventry the other day and I went into a shop and asked for a bacon butty. The lady asked 'a batch?', and I said 'no, I only want one...'. I'll get me coat.
Post 263106 by dave stew on 2009-10-07 22:13:09
I still refuse to call them 'cobs'. You can see I'm settling into Nottingham life, can't you?
Post 263111 by cornclose on 2009-10-07 22:25:52
What are they where you originate from then? Where I grew up they are 'bread cakes'.
Post 263237 by dave stew on 2009-10-08 19:28:53
Barm cakes!
Post 263244 by Tomcat on 2009-10-08 20:02:31
Yaaay for Barm cakes, why can't everywhere speak the same?, I was in Stoke many,many years ago at a chipy, I asked for a barm cake and the woman behind the counter looked at me like I had two heads!!!..
Post 263248 by p fandango on 2009-10-08 20:06:37
we actually had an hour long chat discusion in class about what batches/baps/rols/buns/sarnies are called in different places, the greasy spoon knew what i meant when it came to lunch so i was happpy lol
Post 263250 by cornclose on 2009-10-08 20:15:24
"Barm Cakes" ? Sounds like something off Coronation Street! I know what a "barm pot" is - a bit of a daft lad...
Post 263268 by The Flying Moose on 2009-10-08 20:57:20
This seems to have gone slightly off track me thinks :) I just call them rolls...
Post 263353 by lance on 2009-10-09 10:22:26
Eat less Barm cakes cobs and babs will help you go faster!
