Post 235559 by 5seaterT5x2 on 2009-06-16 12:31:52
thinking about bit of an upgrade on door speakers dont need to go mad but something reasonable any thoughts on these? and in paticular will they fit? ;-) Cheers Gareth
http://www.bluespot.co.uk/stock/spkr1_3.asp
Post 235577 by p fandango on 2009-06-16 14:25:44
yeh they should fit fine, you'll have to drill new mounting holes for the bottom lugs tho as Volvo are pains & put the lugs on there speakers higher up. I had clearance issues because the tweeter stcuk out so much it hit the grilll, but i think you'll be fine with those (even then i just cut out the reinforcement & that cleared it)
Post 236031 by 5seaterT5x2 on 2009-06-18 21:59:13
[quote=p fandango;235577]yeh they should fit fine, you'll have to drill new mounting holes for the bottom lugs tho as Volvo are pains & put the lugs on there speakers higher up. I had clearance issues because the tweeter stcuk out so much it hit the grilll, but i think you'll be fine with those (even then i just cut out the reinforcement & that cleared it)[/quote]
oh rite ok cheers for that i'll try n get em ordered up i think
