Post 234336 by Enigma666 on 2009-06-10 12:01:49
Looks decent enough but seems you have to get hold of Vol-FCR 1.3 also.
What's it for? Just for resetting lights etc? Or for full diagnostics.....you also need to make sure your laptop has serial connections....or you will need a serial to usb convertor too.
Post 234339 by BigV on 2009-06-10 12:31:55
[quote=Enigma666;234336]Looks decent enough but seems you have to get hold of Vol-FCR 1.3 also.
What's it for? Just for resetting lights etc? Or for full diagnostics.....you also need to make sure your laptop has serial connections....or you will need a serial to usb convertor too.[/quote]
I want to read all the fault codes and reset the service lights etc.
I am planning on getting a 9pin to USB converter from Maplins
Post 234342 by Yosser on 2009-06-10 12:42:44
I have tried to use a usb>serial adapter with VOL FCR and it didn't work, I ended up getting hold of an old laptop with a serial port (thanks Jase) and it works fine.
There is a new version of VOL FCR out which does work with USB.
