Rica 310
Post 232273 by Enigma666 on 2009-05-31 18:21:40
Fitted a RICA 310 over the weekend to my C70 T5 (wow :D)
Only thing is I now seem to get a slightly.....jolty acceleration like spinning the wheels (which I am not)...happens in all gears...anyone any ideas?
Cheers :)
Post 232275 by t5 pete on 2009-05-31 18:29:30
It could be a problem with the boost being unstable i had this problem and put a different boost controller on which sorted the problem
Post 232283 by Enigma666 on 2009-05-31 19:11:00
Thanks Pete....would have thought this would happen with the standard ECU levels but guess not :(
Luckily I got another BCS from Nads :)
Just gotta find the damn thing now lol
Post 232289 by Mrsmopp on 2009-05-31 19:23:22
Welcome to the world of remaps :D!!!
I always found when first mapped it took a few miles for the ECU to adapt to the new parameters ;)
Post 232291 by Al115 on 2009-05-31 19:31:21
It's not one of those expensive "revs are rising but I'm not going any faster" syndromes is it?? :)
Post 232292 by Enigma666 on 2009-05-31 19:35:13
lol nah....definitely goes better in all gears :P so not a syndrome...unless I am just looking for reasons to fit a Garrett lol
[quote]Welcome to the world of remaps !!!
I always found when first mapped it took a few miles for the ECU to adapt to the new parameters [/quote]
Ta very much :D must say a re-mapped T5 is a lot more impressive than my T4 :D
Post 232416 by Enigma666 on 2009-06-01 15:32:22
Still doing the damn judder.....based on what Moppy said is it worth d/c the battery for a while then letting it go again and see if that helps?
Post 232535 by t5 pete on 2009-06-01 23:45:35
[quote=Enigma666;232416]Still doing the damn judder.....based on what Moppy said is it worth d/c the battery for a while then letting it go again and see if that helps?[/quote]
I would say anything like that is worth a try i hope you get it all sorted also have you read the codes and if so does it throw any
Post 232537 by Mrsmopp on 2009-06-01 23:49:14
A remap often shows up a weak BCS (been there done that) so if you still have the problem after a couple of days driving that would be my next port of call.
Post 232540 by MrMopp on 2009-06-01 23:53:51
Are you sure that after the T4 youre not dropping off the gas because youre scared when it comes on boost ;) :D :saythat: :hidesbehi
Post 232580 by LeeT5 on 2009-06-02 00:47:40
[quote=Mrsmopp;232537]A remap often shows up a weak BCS (been there done that) so if you still have the problem after a couple of days driving that would be my next port of call.[/quote]
Interesting? Mine gets a BSR stage 2 remap on wednesday, so i will let you all know the outcome.....
Post 232606 by Enigma666 on 2009-06-02 09:13:54
Awesome to both you and Pete for suggesting that :D luckily I have a spare one (although the IPD is looking good about now).
No codes....no CEM....no nothing....just jittery boost...doesn't do it on the standard Ecu so must be the BCS...either way, time to get my tools out again lol
Where'd I put that damn trout to smack you upside the head with lol
Oooh here it is :D :troutslap
In all honesty though....damn does it fly compared to the T4....feels heavier (cause it is) but when she moves she reallllly moves :D love it to pieces :)
That would be really useful thanks :D
Post 232608 by Mrsmopp on 2009-06-02 09:21:11
[quote=Enigma666;232606]
[/quote]
I loved the wee T4 its the perfect car for bobbing about in with a little fun factor but the mapped T5 is where the real fun starts - I think everyone should have one of each lol!
Post 232615 by 850 t5 vs 600cc on 2009-06-02 10:02:51
[quote=Mrsmopp;232608]I loved the wee T4 its the perfect car for bobbing about in with a little fun factor but the mapped T5 is where the real fun starts - I think everyone should have one of each lol![/quote]
I will i will just as soon as i get a job...not at the top of my list at the minute. ( well it is just don't tell the GF.)
Post 232700 by Enigma666 on 2009-06-02 16:26:10
Ok.........having thumbed through Vadis for what I am after.....can anyone tell me where the BCS is located....and......what the hell it looks like? I have a part from Nads which came of an S70 T5 of the same year....so it stands to reason I have one of these parts in there (and it looks like the thing I swapped in the T4).
However....there is a unit just off the airbox (under the damn MAF I swapped typically) and Vadis seems to point at this as the BCS....anyone shed some light for a T5 convert?
:D
Post 232705 by Enigma666 on 2009-06-02 16:44:41
Ignore me :( found out what part it is.....and low and behold it is the part I didn't get of Nads lol.....f'in typical :)
Anyone got a BCS they wanna part company with? :D
Ok....now extra confused....a look on ebay has the bcs looking like this?
Is that correct or should it look like this?
Post 232760 by t5 pete on 2009-06-02 21:33:07
Hi enigma it should look like the bottom pic its the one right at the bottom at the right hand side i have a brandnew one which i bought thinking it was the bcs but turned out to be a air leak it cost me £42 from rufe if you want it you can have it for £30 delivered its never been used so pm me if your intrested.
cheers pete
Post 232761 by Enigma666 on 2009-06-02 21:39:32
PM'd :D
Post 232773 by Enigma666 on 2009-06-02 22:09:55
Awesome mate :D send the request :)
Post 234198 by Enigma666 on 2009-06-09 20:58:57
Well, fitted this and my jolt is still there :(
Anyone wanna enlighten me as to what is the issue?
Only happens if I actually floor the pedal, ease on the power and it is good (and fast) as gold....now getting very confused :(
Post 234207 by Mrsmopp on 2009-06-09 21:12:42
Its not something silly like plugs is it?
Post 234209 by Chad on 2009-06-09 21:14:25
mrsmopp can vouch for that map, if you got it from nads then that was the rica310 that was out moppys s70 t5
Post 234216 by Enigma666 on 2009-06-09 21:19:41
Awesome :D didn't think about the map itself being faulty, plugs were changed (apparently) now I am gonna have to check, bought some new ones anyways to have as spares so I'm gonna change them when I get them if they need it, other than that.....I am at a loss, no sign of boost leaks or anything...car is fine on standard map, so must be something that is caused by the extra stress of the map **scratches head**
Post 234219 by Mrsmopp on 2009-06-09 21:22:51
Oh is that my old one?? I'm not helping you anymore then :grumpy: taking bits of my old baby :worried:
I had that map for about 2 years so I know its a good un, it would boost to about 1.2 to 1.3 bar but would show up as soon as the plugs got tired so that would definately be my next port of call.
Post 234224 by Enigma666 on 2009-06-09 21:27:21
Ty kindly, now let me go punch the mech who said he was gonna service her while I was at work :(
Post 234729 by MARKY70RRR on 2009-06-11 21:39:12
hope you get it sorted soon chris:)
Post 234736 by Enigma666 on 2009-06-11 21:59:44
Well, an update on this one then....d/c the battery (why the heck not) and off I went...issue still there.....changed back to the standard ECU and problem STILL there!!!
Now I am at a loss....the problem is less noticeable with the standard ECU but still there....feels like a total misfire of some sort...no codes, no CEL, no nothing just p!$$ poor performance when on heavy throttle.....waiting for plugs from FB to try that, but if the damn thing is still a problem then I have to contemplate the future of my C70 :(
Post 234740 by Mrsmopp on 2009-06-11 22:05:12
Dont give up! It really does sound like the plugs. The reason I say that is because when I slung that ecu on my V70 it did exactly the same thing, swapped the ecu back and low and behold still present (although not nearly as stuttery) plug change and voila!
Post 234741 by t5 pete on 2009-06-11 22:07:24
[quote=Enigma666;234736]Well, an update on this one then....d/c the battery (why the heck not) and off I went...issue still there.....changed back to the standard ECU and problem STILL there!!!
Now I am at a loss....the problem is less noticeable with the standard ECU but still there....feels like a total misfire of some sort...no codes, no CEL, no nothing just p!$$ poor performance when on heavy throttle.....waiting for plugs from FB to try that, but if the damn thing is still a problem then I have to contemplate the future of my C70 :([/quote]
Hi chris i know how you feel its a rite pain in the bum the next step for me would be a break down in the ignition system either plugs or leads.
With you putting the old ecu back in and still having the same problem but slighter it is obvious the rica had found a weakness in something and this is where the problem may lay.
Have you checked all vack lines?
New plugs/leads?
cheacked acuator?
cheacked intercooler pipes?
The problem sounds like myne was as when you hit the throttle and it doesnt need to be wot but 3/4 of the way it would stutter rather bad and other times just feel like a slight miss.
Post 234757 by Enigma666 on 2009-06-11 22:31:23
Thanks for the confidence boost guys :) (and gals of course)
I'll change the plugs as soon as they arrive from FB (hoping they would have been here by now)...change them, then kick it in the proverbial nuts if it still doesn't work :(
Post 234772 by t5 pete on 2009-06-11 22:42:38
hope it goes well for you bud you coming on flash chat
Post 234793 by timbo_1975 on 2009-06-12 00:24:30
If it is quite an aggressive yet random splutter, then i would definately be going for plugs, plug gaps (close them up 1/10th mm) and try again, rotor arm, leads etc.
The extra boost is finding a weak spot in the HT system...
Post 234796 by AlanG on 2009-06-12 00:47:31
Or trade up to a Citroen C1 and save £2000.
Post 234797 by t5 pete on 2009-06-12 00:52:53
pmsl when we have a problem why dont we just go out and buy new cars and bum the goverment
Post 234798 by Enigma666 on 2009-06-12 00:53:46
Gee thanks for that, I'll....erm........**grabs petrol and lighter, heading for the luxurious alcantra interior**
Sorted :D
