abs/tracs system help required
Post 228777 by SAMXPJ on 2009-05-12 02:35:50
Abs & tracs light coming up intermittently took the car, an S70t5 to the main stealer for diagnostic check and it came up as a ABS 314 error - Right rear wheel sensor signal fault in circuit. Then speaking to the garage foreman he told me that more often when they change the rear sensors as a result of this error code it does not cure the problem, changing the ABS module being the next move which then does! Anyone had this problem or can offer any advice please - Thankyou
Post 228824 by Wobbly Dave on 2009-05-12 10:33:05
Usually if it is only 1 wheel then the ABS Module is not yet at fault. Replace the sensor - they are not usually expensive. If it does turn out to be your ABS ECU then I will gladly help out. (see linky for details) http://www.vpcuk.org/forums/showthread.php?t=224
Post 228862 by SAMXPJ on 2009-05-12 13:07:38
Thanks for that Dave, looking at the diagram I thought you had to replace both sensors as they appear to be wired together on the rear ones, the main stealer quoted me £97+vat. What's the job like replacing them?
Post 228868 by Wobbly Dave on 2009-05-12 13:46:47
I am not sure as I have not replaced the rears. I have only ever replaced 1 of the front sensors which was not too difficult.
