A bit came off.
Post 226639 by Loadsamiles on 2009-05-02 18:19:09
This bit. Image
Post 226640 by gazbak1 on 2009-05-02 18:28:53
oo thats not good! how did you manage that? gazbak1
Post 226641 by Loadsamiles on 2009-05-02 18:37:26
I set off.
Post 226642 by Loadsamiles on 2009-05-02 18:38:15
Then I went nowhere.
Post 226648 by Al115 on 2009-05-02 18:54:34
Holy Christ :D
Post 226654 by Loadsamiles on 2009-05-02 20:40:18
I'm quite happy with that. Originally I thought I'd wrecked the diff. (big panic) It was with much relief that I discovered it was only the long drive shaft. I can change the long drive shaft in an hour and a half.
Post 226655 by Al115 on 2009-05-02 20:45:41
So long as you have a spare or can get a cheap one! Diff would have been worse - so that's a result :)
Post 226657 by Loadsamiles on 2009-05-02 21:11:08
Breakers are usually a good source. (normally between £50 and £75) Just need to make sure that it's exactly the same one. the ones with the 3 dimples in the middle CV joint don't fit. The middle CV joint needs to be round and tapered on the outer casing.
Post 226666 by Al115 on 2009-05-02 23:09:14
Well, hope you get it sorted soon and with minimal cost... but cool breakage in any case :D
Post 226671 by siamblue on 2009-05-02 23:53:34
Is it more poor eyesight or does that end look bent as well? have you got a pic of the driveshaft part you need in one piece obviously lol,, as i can keep a eye out for you, Gary
Post 226672 by PaulZX on 2009-05-02 23:58:12
destruction ftw :D
Post 226673 by cameron on 2009-05-03 00:00:45
Try Readview matey :D
Post 226676 by Loadsamiles on 2009-05-03 00:35:05
Readview is where that one came from. ..LOL It came off a perfectly good car. I saw it removed. The one before it went in the middle CV joint, (my fault) and the one before that went at the outer CV joint. Adam doesn't usually have the correct ones. He has loads of the ones with the dimples in the middle CV, but they are a different length. (maybe from auto boxes) I will give him a call though.
Post 226677 by Loadsamiles on 2009-05-03 00:49:01
The top one in the first picture (there it was before it broke) The bottom one is wrong! Image Image Image Image Image
