Brake noise after new disks
Post 226606 by BigV on 2009-05-02 11:58:41
Can anyone help me out here? Last week I had my wheel nuts drilled off so that I could get new front brake discs fitted..... they are drilled & grooved off ebay and I also fitted EBC red pads. Since then I have had a droning / groaning kind of noise all the time from the front of the car (especially on the left) and the brakes seem very loud under braking. I am also having steering vibration between 60 and 80mph, mainly when not accelerating. I had all 4 wheels balanced and a new tyre fitted which has made the vibration less (but still there) and made no difference what so ever to the braking groaning noise. Could the brakes be warped or binding on? Could this be caused by a warped / buckled alloy, and is it actually possible that the garage damaged my alloys or hubs when drilling off those locking bolts? sorry for the million questions! ps, anyone got an 850 they want to swap? lol
Post 226610 by polak t5r on 2009-05-02 12:52:17
whats the spec on your car mate
Post 226612 by Al115 on 2009-05-02 13:08:26
Do the wheel hubs get hot when you have driven the car?
Post 226614 by cameron on 2009-05-02 13:17:29
The steering vibration could be a buckled wheel, i had the same thing with mine a few years ago :( The droaning noise, could it be the wheel bearing :confused: Ive seen the wheel bolts being drilled out and it didnt affect the wheel :)
Post 226618 by BigV on 2009-05-02 13:27:41
[quote=polak t5r;226610]whats the spec on your car mate[/quote] What do you mean? Standard size brakes for the car, just drilled&grooved..... nothing else is altered apart from a chipped ECU. The brake disks do appear hot to touch & radiate heat after driving, is that abnormal? I should point out that the car had no issues prior to having the wheel nuts off and disks changed, so I think a wheel bearing is unlikely?
Post 226647 by Al115 on 2009-05-02 18:53:51
Discs can be hot no problems, but if the hub or wheel seems particularly hot then that might point to binding brakes - a sticking calliper for example - that's what I was getting at. Have you tried spinning the wheels when the car is raised to check that?
