Help required on ABS Module
Post 225361 by SAMXPJ on 2009-04-24 18:45:43
Does anyone know if a non-tracs ABS module can be used to replace a tracs module, I think my module's gone belly up and I have a spare module same year on a S70 t5 and as I never use the tracs anyway? thanks for any info
Post 225462 by Alan M on 2009-04-25 12:17:44
Yes it will work for the ABS only. I have tried a non TRACS unit with ABS for my car with TRACS and ABS and it worked but you will not have the use of the TRACS facility.
Post 225477 by SAMXPJ on 2009-04-25 14:32:59
Thanks for that Alan but as further developments are now taking place I'm thinking it might be a senser or pulse ring on one of the front wheels. The lights are now coming on now and again and after jacking the front wheels up and trying to remove rust from the serration's on the pulse ring attached to the cv joint the light has'nt come on since but probably just a coincidence. Looks like I'll have to pay the main stealer for a diagnostic check to see what's going on!
