850 glovebox catch
Post 223577 by Johnny5 on 2009-04-13 20:10:19
Yup........ yep another person looking for an 850 glovebox lid/lock Thanks to Johnboy for supplying me a whole lid, but the catch was u/s on that one too :( Thanks John
Post 223585 by Hallsy on 2009-04-13 20:38:02
If it's the catch mechanism in the lid, they can be repaired. If you look at the mech, you'll probably find that the metal piece that operates the latch has a broken pin. Depending which pin has broken you can drill and tap the catch and replace the broken pin with a bolt or stud. There's a writeup on the net somehwere but I'm not sure where off hand, lol! EDIT: Found it http://www.quickbrickmotorsports.com/tech_glovebox.html on mine it's the other pin that has broken but I will just drill and tap it the same, but use a small stud instead of a bolt, and use studlock to keep it tight.
Post 223594 by Johnny5 on 2009-04-13 21:22:50
Im gutted, that looks like a neat repair...... But that triangular catch mechanism is missing on both of the lids ive got! grrrrrrrrrrrrrrrrrr
