Cooling Problem?
Post 222544 by Paddy O on 2009-04-08 17:31:18
I noticed that after a run the radiator fan no longer kicks in for that few seconds when I turn off the engine, instead I can hear gurgling & hissing from the expansion tank - & now steam:frown: The temperature gauge is always in the middle when warmed up and she drives as well as ever at 156k - I have never been able to hear the cooling fan so I don't know if it kicks in at all.... it ain't blown up so I guess it does. So today I took her for a run, gauge shows normal, lifted the bonnet - & the cooling fan didn't come on at all. I suspected the coolant temperature sensor (9186486) but it shares with the temperature gauge (?) I think, which works. Disconnect the sensor wires and the gauge stops working but the fan turns (still nice & quiet I must say), until the engine is re-started. I'm a competent enough mechanic but this has made my minisule brain hurt. Is is a bad relay do you reckon? And you you guessed it, does anyone know the part number if it is. Help please folks.
Post 222550 by Ron@iPd on 2009-04-08 17:55:06
If you turn the A/C on does the fan come on? If so, the relay and motor are good and the temp sender is most likely bad. If you turn the A/C on and the fan does not turn on the relay or the fan motor are bad. Just a thought.
Post 222552 by Paddy O on 2009-04-08 17:57:16
No A/C mate but thanks.
