What next ~ flat spots in acceleration
Post 222017 by Max Headroom on 2009-04-06 00:13:51
I have changed the MAF, crank sensor, cam sensor and ECU on my Volvo T5 and it still runs flat in a couple of spots when accelerating and is sometimes hesitant when waiting at a junction, it will not idle and the throttle needs a blip to keep it going. After hard acceleration it "pops and farts" so I am guessing O2 sensor? Any suggestions?
Post 222039 by t5 pete on 2009-04-06 12:29:47
Have you cheacked your intercooler pipes
Post 222269 by Max Headroom on 2009-04-07 13:07:02
Checked them as well as I can, took off and cleaned the IAC
Post 227165 by woz on 2009-05-04 22:37:14
Get it tuned up by a proper diagnostics outfit. Either Hometune or similar where they come to you with a well equiped van, or ask around locally for a good place. I know of a couple in Bristol, and several I would NOT use. Or you are looking at an RR session at HLM and that will will be money well spent, not only to cure the problem but restore a level of performance you prob never knew you had. And better mpg to help pay for it all. You could just ring Hamish and have a chat he may point you in the rioght direction. W
