Remote Locking
Post 218212 by Pete_T5 on 2009-03-15 13:42:35
My drivers door doesn't always lock when using the remote. The lock knob on the door goes down & then immediately comes up again. You have to then unlock & lock again to get it to stay down. All the other doors do lock. Any ideas ?
Post 218218 by thebadger on 2009-03-15 15:21:31
My car has this feature, it's ex-plod. Basically it was designed to keep the crims in the back while mr plod gets back in the car. Lock the car & wait about... 30 seconds? Should click back in on its own!
Post 218271 by RPM on 2009-03-15 19:40:39
This is actually common fault with Phase 2 V70's. If have have read right I don't think this is an ex-plod feature............ If you press and hold the button down when you get out, the others will lock ok. I don't think there is a definitive fix, but try a search on this forum.....
Post 218352 by thebadger on 2009-03-16 00:30:41
In saying that, my rear passenger side door has been poping open (unlocking) randomly for about the last two weeks, this may be an electrical issue, or a loose conector in the door. Check to see if it will lock with the interior button, if not, it may need a reset of the electronics for the thing to work properly...
Post 218353 by thebadger on 2009-03-16 00:41:10
Try performing a reset of the UEM (Upper Electronic Module), this controls the door locks and window operation: - Close all of the doors and bonnet. - Key in position II engine not running. - Hold both the driver window and passenger window switches in the driver door panel in the closed or up position for 5 to 8 seconds after the windows are closed. - Release buttons. - Remove the ignition key. - Operated the remote twice. lock/unlock lock/unlock. This will reset the UEM brain. This can correct faulty operation of the sunroof and/or erratic door lock function. this came off a post by S60-MBS (my thanks!) I may try this myself... fix a few issues again!
