Condensation in Headlamp
Post 216207 by Pete_T5 on 2009-03-01 15:35:11
I'm getting condensation in one of my headlamps. I think it must be getting in around the rubber grommet for the hid kit which you have to fit in the black plastic bulb cover. Any suggestions for what to use to seal it ?
Post 216253 by cornclose on 2009-03-01 19:07:52
No, but 4 out of the 5 V70 T5's I looked at had this problem, so I guess it's a 'feature' of some. Not on my current car though. In the past with other cars, I've got rid of it by using a hair dryer, but unless you solve the root cause, it'll be back in time.
Post 216257 by v70torslanda on 2009-03-01 19:14:49
Don't use a jetwash - don't let anyone near it with one. Check out Rufe for some modded rear covers. (They were fitted with a 'breathable' membrane to cure that specific problem) If it persists live with it or part with something like 400 quid. Hmmm, hard choice! J
Post 216261 by thebadger on 2009-03-01 19:52:44
Yeah, my headlight (drivers) has water.. I put it down to the odd jet wash that it gets (not that often, but who can be bothered washing it in the cold!), I had this PRIOR to fitting hids... so, not the cause!
Post 216265 by walter leever on 2009-03-01 20:14:24
I used to have condensation in left one(never in the right one:confused:) I've waxed my car lats week(by hand)and also did the headlights(it's possible with the wax i use to do even the windows)and now it's gone.:B_thumb:
Post 216334 by ade74uk on 2009-03-02 12:18:52
hi, I took the black spinny thing at the back of the headlight, the bulbs heated it up and the condensation went away. Give it a go worked for me,
Post 216428 by Pete_T5 on 2009-03-02 22:16:52
Sounds like a common problem. I did get rid of it briefly by blotting it with rolled up kitchen roll & then a hairdryer but it soon came back. [quote=ade74uk;216334]hi, I took the black spinny thing at the back of the headlight, the bulbs heated it up and the condensation went away. Give it a go worked for me,[/quote] Ade, Have you left the black covers off permanently ?
