throttle disc?!?!?! D5
Post 216003 by mk3phill on 2009-02-27 20:58:44
hey guys,. my dads got a problem with his D5 (euro4) and volvo want to charge through the earth,.. anyway can anyone get me a picture of the following parts: Throttle disc:- 34H02 Link:- 03H6B its a 2006 D5 (euro4) 185hp engine. thanks Phill
Post 216016 by gazbak1 on 2009-02-27 22:37:15
this is a policy action i thought but easy to do at home. you have to take the fuel injectors out, remove intake manifold then the is a line of 5 throttle disc's on a bar, remove these and replace with new. also fit the linkage. refit in reverse order. also dont forget to replace the copper injector seals and the intake manifold gasket. hope this helps gazbak1
Post 216019 by mk3phill on 2009-02-27 22:53:30
do you have any pictures its all info for my dad but i cant get home to help him
Post 216022 by gazbak1 on 2009-02-27 23:15:02
sorry no pics, used to work in a volvo dealer
Post 216525 by Rufe on 2009-03-03 16:39:51
These days there is a repair listed, we do not replace them generally. If it helps here is the info for this job.... this is a job for a level 2 technician, so if you attempt it its at your own risk of course. Photos may vary slightly. DESCRIPTION: A method has been developed to repair the swirl system instead of replacing it. This method should be used in order to save time, money and improve the quality of the repair. SERVICE: Repair instead of replacing swirl system on vehicles within limitations above. See the attachment for the method. PARTS REQUIRED: Service Kit - 31293291 x 1.0 Retail Price £3.97 inc vat Butyl Tape - 1161783 x 0.1 Retail Price £2.64 inc vat Coolant - 9437650 x 0.1 Retail Price £4.65 inc vat SPECIAL TOOLS REQUIRED: Drill - 9814117 x1 Socket - 9512885 x1 Retail Price n/a (Deep 19mm Socket) Removal/Installation Procedure: Image Image Image Image Image Image Image Hope this helps (click images above to enlarge) Simon
Post 216538 by mk3phill on 2009-03-03 18:15:04
thanks dude, i shall pass this info onto him.
