T5-t5r
Post 213699 by LAMS7754 on 2009-02-15 19:29:29
Whats the difference between a 850 t5 and a t5r, if putting an engine from a t5r into a t5 would the ECU need to be changed
Post 213788 by t5 pete on 2009-02-15 23:11:05
there the same really appart from the t5r having a little more boost which is controlled by the ecu so if you want the extra power then put the ecu in
Post 213802 by Axl on 2009-02-16 01:45:47
If thats the case why pay the extra for an R just to get slightly lower/stiff shocks (which can a pita on rougher rd's) and alcantara (or whatever the hell its called) seats...when you can either fit the R ecu or get the T5 ecu "up'ed". After all, theres only about 25hp diffirence...
Post 213827 by Tomcat on 2009-02-16 11:33:55
If your just after the extra horsepower then there's no contest, your just as well getting your standard T5 chipped, they both give the same output once remapped anyway. However, the R wasn't just about a little extra power, it had leather and Alacantra trim, climate control, 17" wheels, slightly lower and stiffer suspension, Wood grain dash, premium sound system with 6 cd changer and a front spoiler. All depends what you want from the car doesn't it?
Post 213885 by t5 pete on 2009-02-16 18:51:39
you forgot someting tc lol they were made in limited numbers, and a good clean one will be worth alot more than a t5
Post 213907 by Tomcat on 2009-02-16 19:46:28
Lol, this is true....I sat here trying to remember the differences and completley missed the obvious stuff.
Post 213953 by Saaamon on 2009-02-16 22:34:48
Its all about the R's :) But like tomcat said its not just about the extra bit of power, its the whole package.
