Post 212246 by 888dee on 2009-02-07 16:28:32
I've got the NSR foot brake dragging, stripped down the brakes, caliper, sliders, guides etc all healthy, piston pushed back easily ruling out the flexi, hand brake mech also good.
looks as though the master cylinder has been replaced not to long ago so now thinking the abs unit could be the root of the problem....
thoughts?
Post 212273 by cookie on 2009-02-07 17:34:04
what was condition of handbrake shoes. as lining can be loose, causing wheel to drag/clunk/knock/lock.......... delete as aplicable :D
Post 212294 by 888dee on 2009-02-07 18:18:25
shoe linings are in good condition, feel it's a problem with the hydraulics as the whole disc face is blue with the heat....
Post 212413 by 888dee on 2009-02-08 10:29:39
investigated further, it's had a new caliper on the other side and I've found new locally which I can get today for £56 so gonna do that :)
Post 212458 by 888dee on 2009-02-08 15:49:10
I lied, wrong one at the factors and they don't have the right one :(
Post 212463 by Dangerous Dave on 2009-02-08 16:12:30
The 850 AWD rear calipers are based on the front calipers off the early 940.
Post 212509 by 888dee on 2009-02-08 18:55:29
fronts? are you sure, I've been looking at this and I think it's the same as the multi-linked rear 940, fronts are twin piston efforts...
is what I'm after
Post 212560 by nathT5 on 2009-02-08 21:57:42
[quote=888dee;212413]investigated further, it's had a new caliper on the other side and I've found new locally which I can get today for £56 so gonna do that :)[/quote]
bit cheaper than alfa parts then :eek:
Post 212565 by Dangerous Dave on 2009-02-08 22:08:38
[quote=888dee;212509]fronts? are you sure, I've been looking at this and I think it's the same as the multi-linked rear 940, fronts are twin piston efforts...
is what I'm after[/quote]
seems as though there were 3 different types of caliper for the fronts, one of them was single piston (girling for cars with abs from 1992 onwards)
But anyway, back to the thread. Have you tried Rufe on here, see what he quotes.
Post 212580 by 888dee on 2009-02-08 22:40:03
well ordered a caliper service kit, £11 odds, worth a go :)
Post 212597 by Dangerous Dave on 2009-02-08 23:02:39
Definately mate, let us know how you get on.
