Post 212107 by 888dee on 2009-02-06 22:17:39
anyone point me in the right direction? drain plug, fill plug, gear oil grade and quantity please :) oh and same q's for the diff :) :)
Oil type
Oil level
level and filler plug for the final drive is on the front left hand side of the case, should be the only plug around there.
There was a 'how to' somewhere on here (I think??)..described removing a diff bolt and drilling thru for a drain.. Anyone? Was gonna do exactly that, but not THIS weekend..
cool, thanks chaps, I'll get back under and have look :)
finally got around to this... "oil level plug is difficult to access on right hand drive cars" yer no flippin' joking! and remember my usual spannering is carried out on Alfa's :grumpy:
The our volvos are better to work on as LHD, for instance to get the angle gear out without removing the engine, you have to undo the steering rack pipes (aswell as undo the driveshafts, etc) as they are routed right underneath the angle gear, whereas on the LHD they go nowhere near it LOL. Take the turbo aswell, on LHD cars there's no bloody brake servo in the way! Gonna get mine on the ramps tomorrow, just gonna do a routine check underneath to make sure there's no problems. Got a bit of oil on the driveway again.
