P2 Headlamp Removal
Post 211797 by Pete_T5 on 2009-02-05 17:26:52
I need to remove one of my headlamps. Is it possible to do this without taking off the bumper ?
Post 211804 by thebadger on 2009-02-05 18:05:54
Think not I'm afraid! Did we drop something? Give me a clue as there are tricks to get at some spots!
Post 211817 by Pete_T5 on 2009-02-05 18:27:53
Well i broke the bulb holder for one of the indicators & part of it is now floating inside the lamp with the bulb. The only way i can think of getting it out is to remove the headlamp & tipit out.
Post 211820 by thebadger on 2009-02-05 18:33:23
Wrap a screwdriver (long as will fit) "backwards" with tape, any kind. Gaffer is best, tho masking or even sellotape would do. Slide it gently along the bottom edge, you'll get the bit!
Post 211821 by thebadger on 2009-02-05 18:37:14
p.s. by backwards, I of course mean "sticky side out".
Post 211823 by Pete_T5 on 2009-02-05 18:38:22
Thanks badger. That sounds worth a try. I'll have a go over the w/e if it ain't too cold!
Post 211827 by thebadger on 2009-02-05 18:49:17
A "sticky brush" was what I used to call it, if the tape is narrow enough, just a loop stuck to the tip of a flathead is best, use it like a paint brush to sweep the surface. If it's the idicator tho, tight wound, cross tip. The corners are too tight! Use a torch to look in & try & see where it is first, the first contact with the tape is the best.
Post 211842 by cornclose on 2009-02-05 19:05:04
Super Glue is another option - on a long thin screwdriver...
Post 211846 by thebadger on 2009-02-05 19:12:30
Yeah, but once you've smeared it all over the inside of the lense.... how would we be getting this off? Tape, used properly will work without any difficulties!
Post 211884 by cornclose on 2009-02-05 21:28:13
Yes, make sure you don't get it on anything you don't want it on! That said, as it's a contact adhesive, only a tiny amount is needed and it's strong enough to carry a lot of weight, so a tiny blob would suffice. Tape is the better option though - if it's strong enough.
Post 212247 by Pete_T5 on 2009-02-07 16:30:06
I think i'll have to resort to removing the headlamp. I couldn't get a screwdriver in as access is too limited so I used a large cable tie instead. But i couldn't get it to stick sufficiently to lift the bulb up anywhere near the opening. :frown:
Post 212270 by thebadger on 2009-02-07 17:27:25
Which side is it on?
Post 212272 by cookie on 2009-02-07 17:30:00
I think that bumper removal on P2's is only a 2 minute Job
Post 212275 by wegal on 2009-02-07 17:39:09
[quote=cookie;212272]I think that bumper removal on P2's is only a 2 minute Job[/quote] Its a pain in the arse... lol. I started then gave up on mine but then again im lazy
Post 212279 by thebadger on 2009-02-07 17:53:53
What side is the light on, you can remove the washer pipe on the drivers side or remove the air box on the passenger side... Easy access then!
Post 212295 by thebadger on 2009-02-07 18:20:05
Did you consider a hoover hose gaffer taped to a length of garden hose? Use suction to pick it up & pull it out?
Post 212312 by gazbak1 on 2009-02-07 18:49:26
dumper removal take 5mins. give me half an hour and il do a how to for removing p2 front bumpers gazbak1
Post 212319 by wegal on 2009-02-07 19:01:52
[quote=gazbak1;212312]dumper removal take 5mins. give me half an hour and il do a how to for removing p2 front bumpers gazbak1[/quote] Thought you said it took 5 mins looooool
Post 212334 by gazbak1 on 2009-02-07 20:07:43
lol had to go out i will start the how to now. Start the clock.... gazbak1
Post 212337 by gazbak1 on 2009-02-07 20:29:19
Image #1 open bonnet and you will see 5 or 6 clips, press the middle on the clips down until it clicks, then lift out. #2 carefully remove the rub strips by gently pulling at the corner (be very careful not to break the clips) once removed on both sides you will see a 13mm bolt, remove bolt. #3a for cars with pressure washers like mine in pic, pull the cover out and carefully unclip cover. #3b for cars with headlamp wipers, flip up cover at shaft end, remove 8mm nuts, carefully wiggle and pull wiper arm off, pull washer pipe of from the wiper arm. #4 unscrew t25 torx screw and press in. now starting from one side (find someone to help) pull the bumper forward. Image job done! gazbak1
Post 212344 by Pete_T5 on 2009-02-07 20:45:50
It's the drivers side & i did remove the washer bottle pipe. Still not enough room. I'll give the hoover idea a go & if that doesn't work i'll take the bumper off. Thanks for help :B_thumb:
Post 212348 by gazbak1 on 2009-02-07 20:53:54
post a pic of your hids as these have been my next mod for about well since i bought the car nearly 2 years ago lol gazbak1
Post 212350 by thebadger on 2009-02-07 20:58:02
Sweet dude, I think you'll do well with a suction hose. I thought it was part of the bulb, or the holder, not the whole bulb! You'll do ok with a hoover/vacum!
Post 213545 by Pete_T5 on 2009-02-14 17:33:23
Done it! Need a new bulb holder now though. Managed to do it by just removing one side of the bumper & leave the other side on. Thanks for help :B_thumb:
