HID Bulb Failure Warning
Post 211654 by Pete_T5 on 2009-02-04 19:50:40
I fitted an HID kit to my P2 V70 but it triggers the bulb failure warning for dipped beam. Has anybody else encountered this ? Is there a fix for it ?
Post 211779 by thebadger on 2009-02-05 14:09:31
Error kit mate, it thinks the bulb has run away! http://cgi.ebay.co.uk/BULB-WARNING-ALARM-RESISTOR-FIX-FOR-HID-CONVERSION-KIT_W0QQitemZ370133871810QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item370133871810&_trksid=p3286.c0.m14&_trkparms=72%3A1700%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 This should sort it!
Post 211889 by Pete_T5 on 2009-02-05 21:37:24
I found this on the VOC site. Has anyone done this to fix it ?
Post 211895 by hamish on 2009-02-05 22:42:06
[quote=Pete_T5;211889]I found this on the VOC site. Has anyone done this to fix it ?[/quote] Hi Pete, I did this to the shunt on my own car 4 years ago when I fitted HIDs. The lights and the CEM have been fine for 4 years and 50,000 miles. Regards, Hamish. Tip drill a very small hole.
Post 212028 by Pete_T5 on 2009-02-06 19:00:35
Did you fit any resistors too Hamish or just drill the shunt ? Where is the CEM ? Is it under the steering wheel ?
Post 212173 by Alan M on 2009-02-07 10:11:25
What wattage bulbs and ballasts are you using? There are 55W ballasts and bulbs available that have worked on my uncles S60 D5. I have 35W ballasts and bulbs in my car which is an 850 so maybe it may help with the 55W kits.
Post 213546 by Pete_T5 on 2009-02-14 17:40:35
I fitted the pair of resistors to fix this in the end & decided against bodging by drilling the CEM shunt resistor. Now works fine.
Post 216912 by doug kyle on 2009-03-06 22:38:05
I've had the same problem as this on my 54 plate S80. I started with the 35w pro kit from hids4u. This kit worked very well for 6 month without a problem, so i then upgraded them to the 50w kit from the same place. So far i have went through 2 sets of resistor packs & 10 15amp fuses. Volvo have checked the car over 3 times now & have found no fault with the car, and they are no thinking that it's the 50w kit giving me all the problems. Drawing too much power or some other rubbish!!
Post 217460 by woz on 2009-03-10 21:05:53
Pete - just dont believe everything you read on here! I have not done this ( I dont have a P2 either) but I have read through the links and tyhe links fromn links from links and some of the posters dont know what they are talking about. e.g - one talks about the HIDS "drawing" a different voltage. Thats rubbish you odnt "draw" a voltage you draw a current. The battery voltage is pretty fixed, the voltage across the load will vary with current. Thats why shunts and ballasts are used. Also there is a link saying the CEM senses a lower resistance of the lower powered lamps. Bong! Power = Vsquaered over R so for same voltage a lower power load (lamp) has a higher resistance. Just be very very careful, unless you understand basic physics and can identify and selctively inbore the bunkum, find someone who can. Good luck Woz.
