Feeler - Kenwood KVT-627 DVD
Post 205866 by Enigma666 on 2009-01-11 20:12:25
I am thinking about stripping the Kenwood DVD player out of my S40 as it is soon to become a track car so no tunes required :) Image KVT-627DVD main features: 7 inch widescreen TFT colour active matrix display New fully-automatic 'Z-Action' open / close mechanism Interactive touch panel control with OSD (on screen display) DVD disc menu direct-touch operation (with highlight-control mode) FM / MW / LW radio tuner with 24 station memory presets Maximum output power 50W x 4 (MOSFET power IC) Three preamp outputs with 5 volt level (front / rear / subwoofer) One RCA AV output (PAL or NTSC, according to source) RGB input for optional navigation computer (KNA-G421) One RCA AV input (PAL / NTSC auto selection) One RCA video input with mirror mode function for rear view camera System Es+ tone control System Q sound preset system Installer and backup memories for audio and video settings DVD video playback DVD+ / DVD- R/RW compatible (video format only) WMA / MP3 decoder for compressed audio files. ID-3 tag display MPEG 1/ 2 video file (.mpg and .jpg) playback Removable front panel section and four digit security code to deter theft Complete with full fitting and operating guide Would want £250 ono for this, comes complete with everything you would need to wired it up (except the illusive ISO cable which I am keeping for my C70) If there is any interest then I will strip it out (it's a big job with the size of the loom installed lol)
Post 206674 by Enigma666 on 2009-01-16 09:49:34
Price drop to £200....anyone want this bit of kit?
Post 206724 by Midnightt4 on 2009-01-16 19:10:35
can you take a pic of it in place on the s40?
Post 206738 by Chad on 2009-01-16 20:33:39
pm..d
Post 207057 by Enigma666 on 2009-01-18 20:20:02
Image Image Provisionally sold. Will update as and when a deal is reached :)
Post 208943 by Enigma666 on 2009-01-25 17:31:49
Still for sale...somebody make me an offer I can't refuse :D
Post 208950 by 5seaterT5x2 on 2009-01-25 18:11:24
[quote=Enigma666;208943]Still for sale...somebody make me an offer I can't refuse :D[/quote] hi does it have /is it blue tooth? Thanks Gareth
Post 208951 by yorkshire R on 2009-01-25 18:11:58
would it be a big job to put in my t4?
Post 208957 by Enigma666 on 2009-01-25 18:24:36
Not a huge job mate, to do it neatly took me about 1 - 1.5 hours. Drop the OEM unit out ---> pull down the cover under the glovebox --> run the loom across there cable tying as you go --> down the side of the car (passenger insides) ---> remove B-Pillar at the bottom (this is tricky due to space)--> up under the rear seats ---> pull back boot lining and place it through the little pocket you have (I drilled a hole here to do this)---> Plug in Harness (from Halfords) Iso converter type thing :) ---> Fit Kenwood Cage into double din space --> Plug harness etc into headunit and enjoy :) All depends where you want the brain unit mounting really and how neat you want it all to be. I personally am really too tidy with my ice installs and like no cables showing....just as easy to hide the cables in some harness wrap or similar for a really clean look though :)
