P2 V70 Front Indicators
Post 204185 by Pete_T5 on 2009-01-04 14:23:56
How do you gain access to the front corner indicators on a P2 V70 ? Do you have to remove the headlamps ?
Post 204202 by thebadger on 2009-01-04 15:45:55
Nope... They are really far round the unit.... the socket unscrews from the cluster. I Highly reccomend the washer filler pipe be removed... one torx head srew holds it in, then move it over slightly & pull it up & out. Then you can really see what's what, helps to do this one first so you know how with the passenger side. HTH
Post 204252 by Pete_T5 on 2009-01-04 18:10:23
Thanks. I'll give it a go.
