Oily pipe
Post 202623 by Loz1 on 2008-12-23 14:31:53
Hi, Can anyone tell me what this pipe is. The appears to be a fair amount of oil on the pipe, should i be worried???? As an additional note, there isn't any oil on the driveway (been stood for a week) Cheers
Post 202625 by BruceT on 2008-12-23 15:31:56
Its the hose that goes from the bottom of the intercooler, over the engine and then to the top of the turbo. Take the jubilee off and have a look inside...
Post 202626 by ajc106 on 2008-12-23 15:31:58
thats one of the turbo intercooler pipes
Post 202629 by Loz1 on 2008-12-23 15:47:00
[quote=BruceT;202625]Its the hose that goes from the bottom of the intercooler, over the engine and then to the top of the turbo. Take the jubilee off and have a look inside...[/quote] Might sound a daft question, but is there any liquid/fluid supposed to be inside before i take it off, or just air???
Post 202632 by Niles on 2008-12-23 16:07:30
just air mate, the intercooler piping has a habit of getting a little oil in it in 99% of T5's.
Post 202634 by Loz1 on 2008-12-23 16:16:29
[quote=Niles;202632]just air mate, the intercooler piping has a habit of getting a little oil in it in 99% of T5's.[/quote] Cheers
Post 202638 by BruceT on 2008-12-23 16:26:40
Yeh, its probably just blow-by. PCV getting clogged? Id take the pipe apart and clean and it all up and then check in a months time.
Post 202639 by Loz1 on 2008-12-23 16:37:57
[quote=BruceT;202638]Yeh, its probably just blow-by. PCV getting clogged? Id take the pipe apart and clean and it all up and then check in a months time.[/quote] PCV????? (excuse my ignorance)
Post 202661 by stainesy on 2008-12-23 17:43:24
mate have you got 2 cold air feeds?
Post 202662 by Loz1 on 2008-12-23 18:05:28
Stainesy, Yep, two cold air feed. Came with the K&N induction kit
Post 202667 by stainesy on 2008-12-23 18:13:00
[quote=Loz1;202662]Stainesy, Yep, two cold air feed. Came with the K&N induction kit[/quote] what K&N kit you got and where in the front of the car can you fit 2 cold air pipes from?
Post 202680 by Loz1 on 2008-12-23 19:04:36
[quote=stainesy;202667]what K&N kit you got and where in the front of the car can you fit 2 cold air pipes from?[/quote] K&N 57i induction kit. Pipework comes up from bottom spoiler grill next to fog light with 4" gap from cone filter
Post 202697 by stainesy on 2008-12-23 21:26:07
[quote=Loz1;202680]K&N 57i induction kit. Pipework comes up from bottom spoiler grill next to fog light with 4" gap from cone filter[/quote] hhhhhhmmmmmm interesteing. have you got any pics mate. would be interested to see that set up. been thinking of improving my cold air feed
Post 202718 by mexybhouy on 2008-12-24 04:18:22
positive crankcase ventilation! PCV!!!!!!!!!!!!!
Post 202719 by Loz1 on 2008-12-24 07:08:55
[quote=stainesy;202697]hhhhhhmmmmmm interesteing. have you got any pics mate. would be interested to see that set up. been thinking of improving my cold air feed[/quote] cleaning the turbo intercooler pipe and PCV later today, will post piccy's of the k&n setup then
Post 202720 by stainesy on 2008-12-24 08:19:20
[quote=Loz1;202719]cleaning the turbo intercooler pipe and PCV later today, will post piccy's of the k&n setup then[/quote] ok mate nice1 cheers
Post 202739 by Loz1 on 2008-12-24 12:05:47
[quote=stainesy;202720]ok mate nice1 cheers[/quote] As promised, the routed pipework. Not very good pictures but i think you'll get it Cleaned the pipework (evidence of oil as was suggested by the forum...thanks again) Decided to have a look at the throttle housing (since pipework was off) to discover the butterfly flap (valve) caked in vanish/sticky deposits and carbon. sprayed that with carb cleaner now good as new (closes properly now). Also changed the dizzy cap, rotor arm, plugs and leads (all were supposed to be done by last owner (think all he had done was clean to leads and dizzy cap because the plugs were coked up, leads brittle and rotor arm was pitted). Still all done now and runs a dream
Post 202758 by Big Pete on 2008-12-24 15:11:29
[quote=stainesy;202697]hhhhhhmmmmmm interesteing. have you got any pics mate. would be interested to see that set up. been thinking of improving my cold air feed[/quote] Here is photo's of my BSR Optiflow kit I have on my 850R, just to give you a photo of another kit you can buy. It costs about £85 and it has the heat surround to stop hot air being sucked up through the air filter from the engine, and uses the original Volvo cold air pipe to flow cold air from the front to below the filter. I bought this because BSR are Swedish and I believe their performance products are generally very good.
Post 202759 by stainesy on 2008-12-24 15:50:43
[quote=Big Pete;202758]Here is photo's of my BSR Optiflow kit I have on my 850R, just to give you a photo of another kit you can buy. It costs about £85 and it has the heat surround to stop hot air being sucked up through the air filter from the engine, and uses the original Volvo cold air pipe to flow cold air from the front to below the filter. I bought this because BSR are Swedish and I believe their performance products are generally very good.[/quote] cheers mate im gona stick with myK&N panel filter as i like a sealed system. was interested in making a better cold air feed the the box tho
Post 202769 by Big Pete on 2008-12-24 17:01:21
[quote=stainesy;202759]cheers mate im gona stick with myK&N panel filter as i like a sealed system. was interested in making a better cold air feed the the box tho[/quote] No problemo! I watched the video on the IPD website of their version of the BSR kit and it was quite interesting to watch. So this made me go for the BSR kit because they are easily available over here. Plus you get a huge induction noise increase which along with the dump valve sounds awesome.
Post 202780 by t5 pete on 2008-12-24 17:44:26
where abouts did you get it from pete
Post 202781 by Big Pete on 2008-12-24 17:49:50
I got it from http://www.nordiccar.com who are the UK distributor for BSR, the BSR part number for the 850 Optiflow kit I got is "4900701". I just phoned them and said what is the cheapest price you can do!
Post 202811 by 850twr on 2008-12-24 22:06:30
cant beat the noise of the internal wastegate through a cone filter on a t5 :D
Post 203212 by Jod T5 on 2008-12-30 00:04:34
[quote=Loz1;202623]Hi, Can anyone tell me what this pipe is. The appears to be a fair amount of oil on the pipe, should i be worried???? As an additional note, there isn't any oil on the driveway (been stood for a week) Cheers[/quote] Any oil in your charge pipe will be coming either from your turbo or the PCV system, which drops oil into the inlet ducting just before your turbo... A little oil is normal and part of the running procedure... high crankcase pressure is not good and can lead to Rear main Seal leakage....With the car at idle place your palm over the open oil filler cap...Any blow back other than a light pulse should be considered a issue... Cheers Jod
