Post 198586 by craig on 2008-11-29 11:47:38
hey all , this could be difficult , I got a v plate c70 convertable so obviously it's a 2 door and the passenger seat won't tilt and slide when you lift the lever , I've taken as much appart as I can and can see that when you lift the lever the lugs don't lift out of the cog so it seems an arm of some sort has come off but I can see no way of gettin in there to have a proper look . The leather is sewn on all round an I can't get at anythin . So does anyone have any idea if this is fixable ? Thanks all ....
Post 198587 by Alan M on 2008-11-29 11:53:23
Have you taken the seat out of the car? It may be a little easier to work on that way if you haven't.
Post 198677 by Adge on 2008-11-29 20:44:45
Do a search, we've talked about this before. I had a small spring detach at lower outside edge, bottom of seat. Can touch small lever to activate micro-switch if necessary. Dealer replaced mine eventually.
Post 201490 by killersuzuki on 2008-12-15 03:10:31
unless U got kids
I always liked getting in convertables the quick way....
fact if it is a kid in the back it would look cool seeing them hop in....
my drivers seat stops and starts...... so I got nuthin'
