Post 197178 by celsis on 2008-11-23 09:37:54
I've just had the front pads and discs changed and I seem to have developed an itermittent squeak that seems to be coming from the front end! It's driving me crazy as I can't pinpoint when it'll start!
Could this be anything to do with changing the brakes?
Post 198030 by jimka on 2008-11-27 10:33:31
as in when the wheels turn? did the garage / you copper grease the rear of the pads? otherwise they will squeak like crazy
Post 198033 by LesRED850R on 2008-11-27 10:41:48
[quote=celsis;197178]I've just had the front pads and discs changed and I seem to have developed an itermittent squeak that seems to be coming from the front end! It's driving me crazy as I can't pinpoint when it'll start!
Could this be anything to do with changing the brakes?[/quote]
Do you think ???
Post 198318 by CONDYBOY on 2008-11-28 12:35:14
Strip em down wire brush them (carriers,hub, rear of padsand slider pins),, be careful not to get grease onto the faces of the disc or the friction surface of the pad. this should stop any skweeking.
