Post 194195 by celsis on 2008-11-07 13:18:04
Folks, I'm gonna be putting the car in to have the belts checked and possible changed as I can find no evidence of it ever being done. Odomoter is 89K. Will it be possible to just change the belts or will I need the idler etc. done as well?
Post 194202 by Alan M on 2008-11-07 13:58:52
What car is it? Its best to change pulleys and the water pump at the same time. You can get good prices for genuine parts from Rufe then get the garage you use to fit the genuine parts if you are not using a main dealer.
Post 194393 by celsis on 2008-11-08 10:56:55
[quote=Alan M;194202]What car is it? Its best to change pulleys and the water pump at the same time. You can get good prices for genuine parts from Rufe then get the garage you use to fit the genuine parts if you are not using a main dealer.[/quote]
It's a 97 S40 2l. How do I get in touch with Rufe?
