13g V 16t swap
Post 193907 by mk3phill on 2008-11-06 00:56:58
just a quick question really,. are there any differences in the mounting flanges, between the two,. ie,. would a 16t be a direct swap for the 13?? thanks Phill
Post 194047 by Dangerous Dave on 2008-11-06 18:06:04
As long as you get the straight outlet 16T then its a straight swap. But you'll need a remap to get the most out of it, as its mapped for a smaller turbo that kicks in at lower rpms. I'm guessing its the 2.5 LPT engine (which the 13G was fitted to), you'd have to be careful how much boost you put through at lower rpms as this can cause some problems in the 2.5 engine. 16T turbo, downpipe and exhaust system upgrade, bigger injectors and a remap will give you somewhere in the region of 280bhp.
Post 194082 by mk3phill on 2008-11-06 19:47:19
thanks man,.. something i was hopeing to hear!! do you have anymore info in the problems that could occure with the b5254t i know main difference against the b5234t is the thinner cylinder liners, are they prone to damage anyway,.. or just with inaccurate settings?
Post 194104 by timbo_1975 on 2008-11-06 20:39:16
Liners are thinner and the rods are made of chocolate. Tim..
Post 194163 by mk3phill on 2008-11-07 00:13:01
i know of the thinner liners,..and know the rods are shared with that of the b5234t,.. so what is it thats specific to the b5254t that can in some cases cause problems with boost input at low rpm,.. or is that just it,. in sense that the rods cannot handle much at all?? i cannot see the thinner liners being too much of a problem if the engine is set up correctly
Post 194180 by Alan M on 2008-11-07 10:30:13
The B5254t lump in yours is the older version of that used in the newer Focus St isn't it?http://www.vpcuk.org/forums/showthread.php?t=18401 This is a thread someone else has been asking about which refers to the newer LPT 2.5 engine.
Post 194229 by PNuT on 2008-11-07 16:37:03
it isnt a route i would want to take, but then ive had a 2435cc block crack on a standard car..... dont forget the compression ratio is also higher on the lpt engines.....
Post 194290 by mk3phill on 2008-11-07 19:11:15
cheeres for the link alan, pnut, compe ratio is higher at 9.0:1 over the 8.5:1 but its nothing that could cause serious problems with correctly ajusted engine and specific components. jus gathering info at the mo, real work is going to come in over next year when i should have a project for uni.
Post 194299 by t5 pete on 2008-11-07 19:25:10
the main thing you need to remember is to get a map that doesnt give high boost in low rpm try to get one that is progressive
Post 194324 by mk3phill on 2008-11-07 20:34:54
if thats the main cause of engine faliure then, its not much of an issue,. im going to be looking into a few diff ways of boost controll and limited boost outputs as a pesonal project
