quick emmisions question
Post 193560 by The Edge on 2008-11-04 21:15:16
Right, this isn't a performance volvo but here goes :) I have an N plate 2.0l 20v 850 that has just passed it's MOT with no advisories, but the lambda reading was on the maximum limit (1.03) While i don't consider this a problem, the car drives fine etc, i'm a little worried that come the next MOT i might have a problem. The car does have a very slight exhaust blow noise when it's cold, and it's quite likely that it wouldn't quite have sealed by the time the emmisons were tested. Would you guys worry about this for next time, and if so what would you do? Somebody told me these are known for cracking outlet manifolds is this so? Ta :)
Post 193563 by jonno12 on 2008-11-04 21:25:29
u do get to 104 on the emissions second test as its an older car itll have 2 tests forthe emisions
Post 193565 by The Edge on 2008-11-04 21:29:32
Fast idle was CO 0.01%vol (0.2 max) HC 76ppm (200 max) Lambda 1.03 (0.97-1.03) Idle speed CO 0.01%vol Sound about right? ta :)
Post 193568 by jonno12 on 2008-11-04 21:37:49
ang on ill tyr and find the results of mine
Post 193569 by jonno12 on 2008-11-04 21:38:36
does sound like mine im sure they were the same as them did it fail on that
Post 193578 by The Edge on 2008-11-04 21:47:43
cheers :) it's passed, it's just if there is a likely problem brewing i've got a year to sort it out :D Though i might need to change the Lambda sensor or possibly get a new/used manifold if it's cracked as that was stated as a possiblilty by someone. The garage said it (the car)was well solid so i'm not overly worried, just wanted to clarify that the emissions were about normal
Post 193580 by stainesy on 2008-11-04 21:48:20
just look ed at my MOT from a year ago and its as follows fast idle CO 0.002 HC 4 lambda 1.003 natural idle CO 0.001 that was a year ago and have my MOT in a weeks time
Post 193581 by jonno12 on 2008-11-04 21:48:34
no should be fine unless you have cr ap luk like me n the rad splits lol a month later
Post 193589 by stainesy on 2008-11-04 21:59:18
[quote=jonno12;193581]no should be fine unless you have cr ap luk like me n the rad splits lol a month later[/quote] LOL i had that a week after buying my car. let me gess it splitt around the top left pipe hole on the rad where the pipe from the thermostat goes?
Post 193712 by jonno12 on 2008-11-05 14:11:11
yep but split right through into the oil cooler on the side aswell so i had water in the oil grrrrrrr
Post 193795 by stainesy on 2008-11-05 20:07:30
[quote=jonno12;193712]yep but split right through into the oil cooler on the side aswell so i had water in the oil grrrrrrr[/quote] sh!t not good.
