850 front door speakers
Post 192100 by The Edge on 2008-10-29 17:43:40
Hi all. One of the door speakers in my 850 has a slight flutter at certain frequencies. I'd like to replace them with an equivalent aftermarket pair but don't know the wattage as it's not on the speaker. It's 13cm and 4ohm if that helps :) If anyone can recommend a replacement that'd be grand Ta
Post 192112 by t5 pete on 2008-10-29 18:16:20
theres a few sony do ones that should be a direct replacement
Post 192114 by The Edge on 2008-10-29 18:19:31
Thanks. Can you recommend a replacement? I'm after replaceing ones that distort with ones that don't rather than an expensive upgrade :) Doesn't need to be exactly the same, just complement what's there already Ta
Post 192191 by LesRED850R on 2008-10-29 22:08:28
[quote=The Edge;192114]Thanks. Can you recommend a replacement? I'm after replaceing ones that distort with ones that don't rather than an expensive upgrade :) Doesn't need to be exactly the same, just complement what's there already Ta[/quote] MB QUART are used a lot as replacement , i have a couple i found here on eBay waiting to go in when i get some sound deadening to do the doors as well, plus one of the rear bass has gone out as well so will look to fix that at some stage too. Volvospeed forum does a lot of I.C.E stuff and have a wealth of info ! Cheers Les M.http://volvospeed.com/vs_forum/index.php?showforum=13
Post 192546 by Terminator on 2008-10-31 16:25:25
Have you tried the Volvo specialist breakers? I got two replacement fronts from Salvo Group via www.partsgateway.co.uk and they are as good as new and guaranteed!
