How to turn off Headlights ?
Post 188333 by Nuckin Futs on 2008-10-14 16:13:38
on my 2001 V70 tdi estate the headlights come on with the ignition. on my old volvo i had a daylight fuse that could be removed so the lights didn't come on with the ignition. is there anything i can do on this one? Thanks Jeff.
Post 188334 by cameron on 2008-10-14 16:16:56
I remember on my old V70 that the last owner cut a wire behind the lights on switch. Not ideal if you dont know which one it is, but the lights only come on when i switched them on. Lee
Post 188338 by Tomcat on 2008-10-14 16:49:11
Don't know if it applies to your model or not but the mod for the 850's was to bend one of the pins flat in the headlight relay, can't remember which pin off hand though.
Post 188351 by ged on 2008-10-14 17:41:02
my t reg 99 c70 has a small flat screw beside the light switch on the dash,if you turn it with an electrical screwdriver through the 3 settings one turns of the d.l.r. lights off.the wifes s60 doesnt have the screw so i don't know if yours will but her car doesnt have the lights permenently on.
Post 188361 by cookie on 2008-10-14 18:02:13
I think you will find P2's is a dealer reprogram, they can set prefernces for headlights
Post 188364 by lutonmatt on 2008-10-14 18:04:47
[quote=ged;188351]my t reg 99 c70 has a small flat screw beside the light switch on the dash,if you turn it with an electrical screwdriver through the 3 settings one turns of the d.l.r. lights off.the wifes s60 doesnt have the screw so i don't know if yours will but her car doesnt have the lights permenently on.[/quote] mines the same have not seen it on any other models
Post 188365 by S60-MBS on 2008-10-14 18:10:22
[quote=Nuckin Futs;188333]on my 2001 V70 tdi estate the headlights come on with the ignition. on my old volvo i had a daylight fuse that could be removed so the lights didn't come on with the ignition. is there anything i can do on this one? Thanks Jeff.[/quote] If its the car in your avatar then its a dealer/Vadis job only.
Post 188372 by cegc70t on 2008-10-14 18:30:33
Hey dont switch them off! if the lights aint on it aint a real volvo lol
Post 188382 by Alan M on 2008-10-14 18:51:49
[quote=Tomcat;188338]Don't know if it applies to your model or not but the mod for the 850's was to bend one of the pins flat in the headlight relay, can't remember which pin off hand though.[/quote] Pin 56b on the lighting relay on the 850 and classic 70. I'm not sure if its the same as yours. I have done this to mine and it works as I have fitted a HID kit to my car. Make sure you get the right pn on the realy to fold over as there are loads of 56 designated pins. HTH.
Post 188440 by Adge on 2008-10-14 21:53:01
[quote=cegc70t;188372]Hey dont switch them off! if the lights aint on it aint a real volvo lol[/quote] And what's wong with other people being aware of your presence!!?? Other makes should adopt the good practise!
Post 188640 by Nuckin Futs on 2008-10-15 20:02:36
I dont mind the side lights being on but it will shorten the life of my HID's if they are on all the time. Going to try the relay pin cutting this weekend, Now wheres my hammer and mole grips!!
Post 188654 by cookie on 2008-10-15 21:00:55
[quote=Nuckin Futs;188640]I dont mind the side lights being on but it will shorten the life of my HID's if they are on all the time. Going to try the relay pin cutting this weekend, Now wheres my hammer and mole grips!![/quote] Ring your local main dealer for price of software upload for turning lights off, the cutting pins etc is Pre ME7, as Mo and I have both said, its a software change required. Cutting pins will simply result in rendering a relay useless, P2 electrics are light years way from the 850 Motronic stuff Ben
Post 188657 by S60-MBS on 2008-10-15 21:07:15
[quote=cookie;188654]Ring your local main dealer for price of software upload for turning lights off, the cutting pins etc is Pre ME7, as Mo and I have both said, its a software change required. Cutting pins will simply result in rendering a relay useless, P2 electrics are light years way from the 850 Motronic stuff Ben[/quote] Phase 2 relays are not cheap either to replace, probably same price as paying a dealer to turn the DRL's off.With a bent pin theres possibility that your will throw a fault code on the info display.
